Burnt my first rye
Burnt my first rye
Followed UJ's rye recipe with 100% malted rye. Fermented mine on the grain, racked, then filtered through cheesecloths ~5 times until there was no more residue. Poured into the still, then diluted with 2 gallons of water bringing the total to ~12 gals. I still managed to burn it, badly.
Didn't add any enzymes to help with liquification. Maybe I should've?
Any other pointers to prevent this next time? I'll probably ferment off the grain next.
Re: Burnt my first rye
use a bain marie/steamer/steam jacket.
now i drink for evil.
What is a "UJ's rye recipe with 100% malted rye"
- MichiganCornhusker
That’s like asking what is the Old Testament!acfixer69 wrote:What is a "UJ's rye recipe with 100% malted rye"
viewtopic.php?t=926
Rye can be a beast.telefonica wrote:Any other pointers to prevent this next time? I'll probably ferment off the grain next.
Stirring while coming up to temp is the only other thing I can think of to help you out.
It can be done, keep at it.
Thank's MCH I remember now that I see it
Thanks for all of the help, guys. Looks like I'm going to have to buy a new heating element and possibly do another vinegar and sacrificial run.
My heating element is just pure black. It didn't burn a solid chunk, it just looks like the rye soup was too much and burned on the element.
I e cooked rye with gas, never an element.
Do you have one of those ultra low watt density elements?
Rye just seems to want to scorch unless you can trick it somehow.
Interesting, I may have to do that.
No, I have a 5.5kW element. I typically get up to boil at or near maximum power before turning down to ~2kW for the run.
Do other grains act the same way? Wheat? Corn?
Other grains? Not in my experience. But it might not be a problem even with rye if you used the lower power setting for the element from the getgo - at the cost of taking longer for a run, of course.
Any other users with internal electric elements have experience they can share? Is 1.5kW too high? 2kW?seamusm53 wrote:Other grains? Not in my experience. But it might not be a problem even with rye if you used the lower power setting for the element from the getgo - at the cost of taking longer for a run, of course.
Get a thumper to strip that.doing shit like rye i usually take all clear i can and the rest in the thumper.dilute the clear to have enough in primary and the thumper gets the mud.no scorching ,never
