Newbie Quesy: Nail Varnish Remover Smell
Used the triple distilled turbo & turbo clear mix, fermented out ok, cleared and left for 24hrs, syphoned off and left for another 24hrs. (Very clear)
Distilled 4 ltrs and threw the first 25ml. Ended up with a very strong nail varnish smelling liquid even after filtering??
This is my first wash through the Airstill system although I did flush it once with water.
Sorry for what seem like a boring old question..
Re: Newbie Quesy: Nail Varnish Smell
Nail varnish? or nail varnish remover, aka actetone? I have had acetone on some washes, usually comes out first...
But varnish?? maybe the still needs a good clean???
Its more like polish remover I think. It is a brand new still.
When you ferment sugars, the yeasts produce a number of alcohols, mainly ethanol, (The good stuff) but also a bunch of others including acetone (which IS nail varnish remover) and methanol, isopropanol, etc etc.. some of these are toxic, but in small doses they just give you a hangover..
Have a look at this link to the parent site http://homedistiller.org/dtw.htm" onclick="window.open(this.href);return false;" rel="nofollow for info on alcohols..
Having said that though, usually you dont get that much acetone in a turbo wash.. how much sugar did you put in?
In regards to washing your still, the guys here will run water and steam through a new still first, then put a wash through and throw the alcohol away the first time around... dont know enough about your particular still to comment though..
Re: Newbie Quesy: Nail Varnish Remover Smell
Ok thanks. I used 6kg of sugar. Started another with the same smell at the moment but am going to try double filtering it.
- Location: Where distillation is legal and the wives don't nag
I believe you're smelling ethyl acetate, and I had the same issue when I used turbo yeasts. You can't separate the acetate from the ethanol because the boiling points are too close together and they form an azeotrope. Before I realized what was going on, I even distilled some stuff 3 times, and the smell was still there. I used baker's yeast and it eliminated that problem.
Nail polish remover is either acetone or the "acetone free" which is ethyl acetate.
Once, during Prohibition, I was forced to live for days on nothing but food and water. W.C. Fields
Attempting to use full dosage turbo yeast in combination with an air still is the crux of your problem, ghostfreak... You might be able to get away with using full dosage turbo yeast with a reflux column still but not with an air still... There's good reason why the brew shops recommend clearing agents and carbon filtering when using turbos - they want more of your money...
We have plenty of inexpensive Tried and True Recipes that don't require turbo yeast and will clear and distill quality spirits without clearing agents or carbon filtering... I'll stand behind Gerber because I've pushed it as high as 14% ABV using bakers yeast and it distills with no off flavor or smell... It's hard for some folks to believe that baby cereal + sugar + water + yeast can get you to almost turbo ABV but it can...
If you're going to continue using the air still, do yourself a favor and nix the turbo yeast... You won't be sorry... The time you save trying to clean up your wash and spirits will be more than offset by the relative ease of non-turbo washes, with only a minor reduction in spirits...
You may find that breaking the spirit down to about 20%
and adding sodium bicarbonate or Sodium carbonate ( two schools of thought on this , do a search to get detail )
and the level of ethyl acetate will be reduced
the search will tell you what the level of addition is
and then redistill
my recommendation to do the search is for education , rather than giving you the answer
and then redistill
The Friendly Spirit
- der wo
I have used the Triple Still a few times. It was the best one of the turbo yeasts. Btw it is no real turbo, because it does not ferment 8kg sugar per 25l, only 6kg. Surprisingly it was very cheap, less expensive as the Vodka Star without liquid carbon, so I bought it.
Yes, ghostfreak should read through the birdwatchers and other threads, we don't need turbo yeast. He will learn much and eliminate the mistakes he did with the Triple Still, whatever it was.
Btw I really would like to have once a bourbon-ferment with nail varnish remover or glue smell. I think, it's the last puzzle for an imitation of cheap commercial bourbons.
