Finally getting to run my still for the first time..!
I read somewhere on this site, that Coopers Lager makes a pretty simple wort for a quick "Scotch" whiskey run. It's true....
At first, the alcohol coming out smelled just like the chemicals I was using at work today to stain & varnish stair nosings. I assume that was methanol. I tossed that, plus a bit more just to be safe.
The next bit smelled a lot better, so I added it to a .75 liter wine bottle 1/4 full of oak shavings. Since the product was still warm, it picked up the "aged oak" essence, & color right away. -Not bad on ice.
I'm sure real grains produce a superior product, but I'm quite happy with the first run.
Thanks Again for everyone's help!
12 min. Old Scotch
Re: 12 min. Old Scotch
that was probably most ethyl acetate, with a solvent smell.Tideliner wrote:At first, the alcohol coming out smelled just like the chemicals I was using at work today to stain & varnish stair nosings. I assume that was methanol. I tossed that, plus a bit more just to be safe.
methanol hardly has a smell.
-I have too much blood in my alcohol system-
One thing to be VERY careful of, is the first run of your still (any still), will clean out the manufacturing junk out of it (left over solder flux, and other nasty trash).
It is very customary (and safest), to do a throw away run first, to get the still cleaned (some do a couple of throw away runs).
You might be careful with this first run. It may not be a clean as you would hope it is.
H.
H.
cleanlyness
yes run a few crap washes or vineger and water through it... it worked for me and i was glad i did run the water....i saw black carbon from my pipes because i had a very hot torch!
A water run will not do a good throughout job of cleaning. It will clean some, but some of that crap simply will not let go, until you run some hot ethanol vapors through it.
Yes, the "cheap" rotten wine, or cheap sugar wash (or even left over heads/tails for ppl who have been distilling), will clean out the sticky nasties.
H.
H.
