Hello All,
I bought still plans off of ebay ( before I found this site ). As it turned out, they were for one of those tea kettle pot stills. I put one together and used a rubber stopper / bung ( that i bought from a brew heaven place here ) to seal the kettle. I drilled two holes in it. One for a thermometer and another for the copper tubing. I ran about 5 gallons of wash through it. I have some booze that I would like to try, but I need to know if heating up that stopper might have caused me some quality issues or if it is safe to drink.
Thanks!
Rubber Stopper / Bung
Re: Rubber Stopper / Bung
Rubber ain't the best.
If the end of the bung is gummy or sticky at all, the alcohol vapor has degraded it and leached some chemicals into your distillate.
I would'nt drink it .. let it be a test / cleaning run .why take a chance on it ? and I would find something besides rubber if it was me .
Does the same home brew shop sell cork bungs? a cork one would be just fine.
Just make a thick dough of flou and water to plug it up.
you can make a soft wood plug/ cork (as popular)a bung for a barrel mite work.(wood should swell to fit tight)
