Acid Blend and Gypsum???
I'm obviously a beginner and am seeking some definition on the application of Gypsum and an Acid Blend...
For one, what is the Acid Blend and where do you get it. And two, what is the purpose of Gypsum and where do you get it as well???? I've done numerous Sugar Washes and now am working a Corn wort.. The recipe I have calls for Gypsum and an Acid Blend??? And I don't know where to find the information or what it is.... Is the Gypsum the same as the Gypsum for Concrete?? Or is it a food grade?? Is the Acid Blend, Citric Acid and ??? Please Help................
Re: Acid Blend and Gypsum???
both can be found at your home brew shop. and yes the gypsum is food grade Theo i do not thank it whould have to be.
acid blend is citric,tartaric and malice acids I whould say you can use citric acid, (lemon juice etc) gypsum is calcium sulphate,
but calcium carbonate (chalk)will also work Id say I do not know why they want both, acids lowers PH. calcium raises it
I never use any thing in grain mash.
So, I'm guessing your recipe consists of Maize, Barley, Water and Yeast.... Any sugar??? I'm using a reflux still........
When using a Reflux Still will everything be scrubbed clean to where it won't make a difference if I'm distilling a wash or a wort??? What I'm looking for basically is a recipe that doesn't have any "crap" in it..... Corn, Malt or, Barley, Water and yeast... And Sugar???
if you do a grain mash you have to cook the grains, to a gelatinize( takes about 1 hour), then cool to 150F (66c) add crushed malt (about 20% of grain bill) keep at this temp about 1/2 hour. (I just rap in blanket and leave over night) then when cooled to 80f (or lower)(27c) pitch yeast.
if you use all malt you can do a infusion mash but not as efficient ,, that you put crushed malted grain in pot , add hot water (about 165f) (74c)
leave at that temp for a hour or so cool to 80f ( 27c) pitch yeast.
You can also do a extract wash (no hops) just add malt extract at about 1lb (1/2 kg) to the gal (4l) of hot water stir,,cool to 80f (27c) and pitch
yeast. this is all much more expensive than sugar wash. not worth the work for "neutrals" If I was going to do "neutrals" Id do sugar with some malt
extract for "yeast food" or you can do a UJSM stile (suger wash with corn) (on tried and true recipes)
I do all grain mash all the time. takes some getting used to. especially corn,oats,wheat. I add no sugar or nutrients.I use well or branch water.
(no chlorine) Iv got a shipment coming, and going to try , 2LB ( 1kg) barley to one lb (1/2 kg) of corn. per gal (4l) water.
then run threw a pot still to git whisky. age in wood for about 1 year?
Pure gypsum should not affect pH if the pH is below about 8.5 (from memory). Calcium carbonate will usually raise pH. Both supply calcium.Dnderhead wrote:I whould say you can use citric acid, (lemon juice etc) gypsum is calcium sulphate,
but calcium carbonate (chalk)will also work Id say I do not know why they want both, acids lowers PH. calcium raises it.
Be safe.
Be discreet.
And have fun.
Be discreet.
And have fun.
Gypsum is Plaster of Paris. Get it any craft or artist supply. Lifetime supply for $5.
Shine on!
went and did some research, and yes gypsum is added for the calcium that yeast need . but should not be added unless you know it is needed.
according to the brew site yeast need about 50 PPM . most water has that in it unless very soft. (do not use "softened" water) adding to much
calcium can also be bad. That explains some of the reasons why I have good luck with my mashes.I use well water(mostly) and spring water.
If you have water from a reservoir or use rain water then you mite need some. but try it first with out. they also suggested not to add acids
until after the mash is made. doing so can lower the PH to much.as the grain and water can effect the PH. (you want a PH of 5--5.5)
(rain water can be acid)
its all in the water
Hey Dnder, when you say barley is it always malted or just barley? I'm guessing malted but just to make sure. Thanks BD2LB ( 1kg) barley to one lb (1/2 kg) of corn. per gal (4l) water.
I do all my own stunts
I got a good buy on malted barley had to take a bunch,(cost+) but it will git used. so that is what I'm trying. barley malt and some corn to lighten it.
I need one heck of a big pot!
Will a medium coarse corn meal work for this blend. I happen to have a big bag of it. Cheers, BD.
lookingaroundmyshopwithdifferenteyes
I do not know why not I'm going to boil the corn (1lb (1/2 kg) to the gallon) for 1/2-3/4 hour then add malt (1 lb (1/2 kg) to the gallon
cook for another 1/2 hour,,, let it cool to 155F (68c) then add another 1 lb (1/2kg) malt
I thank if I do it in steps that way it wont be so hard to cook the corn?
1.084-og,,,,1.021 fg,,,,8.4 ABV
One more thing Dnder, I only have malted flour, which I guess is malted barley ground fine. I know it works because I use it in my doughs and I get a nice rise. Do you figure the same amount of the flour as the whole malted grain? I dying to get at this one and maybe blend it with the other stuff that's bubbling away. Cheers, BD.
No- it is to help buffer the pH to keep it in a range conducive to amylases...Dnderhead wrote:went and did some research, and yes gypsum is added for the calcium that yeast need . but should not be added unless you know it is needed.
Price Quantity Buy Now
$3.50
Shipped Today Or The Next Business Day!
ABOUT THIS PRODUCT: [MIN210] Gypsum, also known as calcium sulfate, is used as a water hardening treatment when making beer. Having proper water hardness when mashing grains helps to increase the amount of sugars extracted from the grains and promotes the precipitation of haze causing proteins during fermentation. In the case if Gypsum it also helps to round out the bitter flavors from the hops. Gypsum is also used when making Sherry and other Spanish type wines. Heavy doses are added in a process know as "plastering". Adding Gypsum to your Sherry will help emulate the characteristics that are present in these wines.
$3.50
that malt flour is malt that is ground /sifted ,,it whould be good flavor and make happy yeast.
Did it just now.
3 kg corn
1 kg rye (what the hell ... caution to the wind)
1 kg malt
15 kg water
Do I pitch on the grains? Was thinking 15 grams baker's yeast in the morning? Thanks, BD.
Maybe this topic has veered from the core. My apologies to the Mods.
3 kg corn
1 kg malt
15 kg water
I read elsewhere that gypsum is added to help remove chlorine? is that correct?
If so would calcium carbonate also assist in the same way?
ref:
https://homedistiller.org/grain/wash-grain/whisky" onclick="window.open(this.href);return false;" rel="nofollow
(search for gympsum on the page)
ref:
