Orange must
Orange must
Can there be to much sugar in a mash? I am going to do a orange must and wasn't sure if I should add sugar. I'm doing a 5 gallon must and have about 80 large oranges
Re: Orange must
Of course, if you overdo it with sugar you will have disadvantages especially for yeast. In your specific case, I would try to limit or eliminate sugar in the recipe not only for the problems already mentioned but because you get more flavor overall. For oranges, if you don't want any trouble you have to correct the pH because it is generally a very acid fruit.
Re: Orange must
OG and ph. I doubt, unless your oranges are extraordinarily sweet that the OG will be very high. The acidity will make the ph very low. Good luck.
Re: Orange must
Ok I am making the must this weekend thanks for the advice
Re: Orange must
Ph is yeast dependent, I usually keep mine around five. Do your research.
Re: Orange must
Good luck, keep us informed brother.
Re: Orange must
I'm going to be watching this thread for updates.
The wise man has something to say. The fool has to say something.
Re: Orange must
I have done this in the past and a great product came out, I think it will be good for other people too.
Re: Orange must
Mshing In tomorrow I will keep everyone updated how often should I check the ph
Re: Orange must
I’m wondering if it might work to adjust the pH first, with oyster shell, which might take a few days, before adding sugar to get the right OG. Then pitch the yeast and nutrients. An interesting puzzle!
- The Doubler (5 gal pot w/thumper)
Run it, X. Thump it, XX. If you get 1.5, well, I think you can do better!
It's EASY to make good liquor. It's even EASIER to make bad liquor!
Re: Orange must
Slaked lime is much better than CaCO3 for adjusting pH. No puzzle, no waiting for days.
Re: Orange must
Me too! Citrus is a great flavor for whiskey!
Re: Orange must
I stand corrected. Thanks! I’m going to make this my next project.
Re: Orange must
Ok had about 1.5 gallon juice and added 6 fruit cups of mandarin oranges with 4.5 gallons of water ph was 3.2 I added baking soda now ph is at 6.2 I pitched it with ec-1118 yeast so let's see how it goes
Re: Orange must
Keep us updated, you will see that it will work. 4.5 gal is the final quantity? What was the O.G.?Jonsmith8608 wrote: ↑Sun Feb 21, 2021 9:03 pm Ok had about 1.5 gallon juice and added 6 fruit cups of mandarin oranges with 4.5 gallons of water ph was 3.2 I added baking soda now ph is at 6.2 I pitched it with ec-1118 yeast so let's see how it goes
Re: Orange must
There was about 1.5 gallons of og and 4.5 of waterDemy wrote: ↑Mon Feb 22, 2021 5:16 amKeep us updated, you will see that it will work. 4.5 gal is the final quantity? What was the O.G.?Jonsmith8608 wrote: ↑Sun Feb 21, 2021 9:03 pm Ok had about 1.5 gallon juice and added 6 fruit cups of mandarin oranges with 4.5 gallons of water ph was 3.2 I added baking soda now ph is at 6.2 I pitched it with ec-1118 yeast so let's see how it goes
Re: Orange must
Re: Orange must
Hes had five days ferment time from the op so wonder what's going on with it....
Re: Orange must
I read this wrong what is og?Jonsmith8608 wrote: ↑Mon Feb 22, 2021 9:25 amThere was about 1.5 gallons of og and 4.5 of waterDemy wrote: ↑Mon Feb 22, 2021 5:16 amKeep us updated, you will see that it will work. 4.5 gal is the final quantity? What was the O.G.?Jonsmith8608 wrote: ↑Sun Feb 21, 2021 9:03 pm Ok had about 1.5 gallon juice and added 6 fruit cups of mandarin oranges with 4.5 gallons of water ph was 3.2 I added baking soda now ph is at 6.2 I pitched it with ec-1118 yeast so let's see how it goes
Re: Orange must
O.G. = Original gravity, my fault, I made an abbreviation "too hasty".Jonsmith8608 wrote: ↑Mon Feb 22, 2021 2:14 pmI read this wrong what is og?Jonsmith8608 wrote: ↑Mon Feb 22, 2021 9:25 amThere was about 1.5 gallons of og and 4.5 of waterDemy wrote: ↑Mon Feb 22, 2021 5:16 amKeep us updated, you will see that it will work. 4.5 gal is the final quantity? What was the O.G.?Jonsmith8608 wrote: ↑Sun Feb 21, 2021 9:03 pm Ok had about 1.5 gallon juice and added 6 fruit cups of mandarin oranges with 4.5 gallons of water ph was 3.2 I added baking soda now ph is at 6.2 I pitched it with ec-1118 yeast so let's see how it goes
Re: Orange must
Oh ok thought you did it already
Re: Orange must
I'm not sure I just tested the ph I'm still kinda new to thisDemy wrote: ↑Mon Feb 22, 2021 2:18 pmO.G. = Original gravity, my fault, I made an abbreviation "too hasty".Jonsmith8608 wrote: ↑Mon Feb 22, 2021 2:14 pmI read this wrong what is og?
Re: Orange must
A bit of clarity .... o.g. It is a measure that tells you how much sugars you have in your juice and therefore the alcohol potential. It has nothing to do with the pH. To measure O.G. Densimeters or refractometer are generally used.Jonsmith8608 wrote: ↑Mon Feb 22, 2021 4:21 pmI'm not sure I just tested the ph I'm still kinda new to thisDemy wrote: ↑Mon Feb 22, 2021 2:18 pmO.G. = Original gravity, my fault, I made an abbreviation "too hasty".
Re: Orange must
Probably querying this
I think its a Typo and 1.5 gallons of OJ ( orange Juice ) was meant. Hence the following confusion and explanation of what OG stands for .
Nice pickup wpkluck .
Incidentally , I used to make a lot of Orange wine years ago . Something like juice of 12 oranges , 1kg sugar topped up to 5 liters of water . Wine yeast nuetrient and EC 1118.
No pH buggering around needed . It just fermented fine and made a really dry orange wine .
