Pigroasters new optimal profile for oak aging sticks
Re: Pigroasters new optimal profile for oak aging sticks
Do you get that great vanilla taste & smell with those times? Or are they released, like in my profiles, after around 75 minutes?
Regards, Odin.
Regards, Odin.
Odin I use the same method as you with the holes but I do it on the BBQ outside as to not smell up the house. Just did some plum wood 1/2"x1/2"x4" the other day.
But what makes you stop the toasting process? That great vanilla taste & smell? Or do you toast even after that? I am looking for a sweet spot that can help me further improve my whiskey ...
Odin.
Odin.
I found that I run my BBQ at a medium temp and not to waste the propane I usually char while BBQ a fish dinner. I don't do it with the steaks as I don't want that flavor in the wood. The wood usually starts to smoke before the fish is done that is when I pull it.
Decided to do a bit of an experiment with profiled oaking sticks.
The complexity of flavors from using toasted and charred oak, as I understand, comes from the spirit contacting charred, toasted and the "raw" or less toasted center portion of the wood. As most profiled oaking sticks impart flavor and color faster, the spirit thus has less time to soak into the wood, and in turn less time to allow the center portion of the sticks to work their magic. And with many of the profiles used, the sticks are essentially thinner and will toast deeper into the center in a given amount of time than would a straight profile stick with the same outside dimensions. Basically, due to shorter oaking time and and a lower amount of "raw" oak in the center of the sticks, we are lessening any affect this "raw" oak could have on our spirits.
My thoughts on how to avoid the issue, if it is in fact an issue or having any effect, was to toast and char prior to cutting the profile, and vary the cut depths in an attempt to regulate the amount of contact the spirit has with different areas of the stick, ie: toasted, charred and raw.
I used 1" x 1" sticks, and made cuts with a thin-kerf 10" tablesaw blade on 2 opposing faces. On one side the center cut is 5/8" deep and the outer cuts are 7/16", and the other has five 1/4" deep cuts. I also took a few and lightly charred the side with 5 cuts after making the cuts with a small butane pencil torch, just to add another aspect to my testing.
For a baseline, I also made some 1"x1" sticks, "standard" pigroaster sticks and some with cross-grain cuts, toasted and charred them along with my test sticks, being careful to char them as consistently as possible.
I have 16 quarts of Booner's all corn that will be used to test my theory. I ran a fast strip then a spirit run and proofed to 66%. I haven't decided how long I will oak for yet, and I am open to suggestions. Probably until it looks good.
I'm not sure if I'm this is a real issue or if I'm wasting my time. Figured the best way to find out is do some testing! Be a month or so before I have any results, and will start a new thread if it produces results worth mentioning.
Any thoughts, comments, suggestions or other input are welcome!
I just put a new profile in the oven. Set at 210 degrees C. This time only for 75 minutes, instead of 90. I am after those sweet vanilla taste & smell!
Making rye whiskey at the same time, so let's see how this works out.
Regards, Odin.
Regards, Odin.
Keep up the good work and the findings, it is all very very much appreciated
75 minutes gives less coloration. The whiskey isn't as dark as the 90 minute one. Or maybe it just goes slower. I will know in a few months if it gives more of that great vanilla taste.
Odin.
Odin.
GeeWhiz stuff,
For fun check out this website:
http://www.timeandoak.com" onclick="window.open(this.href);return false;" rel="nofollow
looks familiar to me. Pigroaster should get a cut of the proceeds.
Have Fun.
Have Fun.
I wake up every morning at the crack of ice
Anyone had much success purely toasting (blue flame) their chunk / chip of white oak? Is it possible to get good results without doing the 45 To 90 min bake ?
Separate question, could it retrospectively bake a chunk that's already been toasted and quenched in wine?
Ive been doing alot of research on "oak alternatives" and wine makers have known for some time that end grain produces a substandard "paper bag'ish" taste compared to side grain. Ive gone through about 25 different companies making oak alternative products for the wine industry and there seems to be a consensus. End grain is to be avoided if at all possible, and end grain takes about a month to extract, vs 3+ months for side grain to extract. It seems coopers not only avoided end grain in barrel construction for leakage purposes, they did it for flavor purposes as well, if only by accident though.ron71157 wrote:GeeWhiz stuff,
Have Fun.
that product on time and oak is basically a TON of end grain. You can read a review here, it doesn't work well...
http://gizmodo.com/we-tried-this-whiske ... 1647799090" onclick="window.open(this.href);return false;" rel="nofollow
- ranger_ric
Shine runnah....
Looking forward to you posting up those results
If you are not willing to learn
No One Can Help You...
If you are Determined to Learn
No One can STOP you!!
We want you to be safe and succeed so start here
- kiwi Bruce
I use the same sticks as ShineRunnah. I like Pigroasters idea better as the cuts are exposing the spirit to the long grain of the oak and not the short grain. I feel the long grain gives a more tannic taste. I put four 1" X 1" sticks in a half gal mason jar of untreated spirit for 24 Hr then replace them with twice used sticks until I get the results I like. I'm using the staves of a used bourbon half barrel that had come apart. The local ACE hardware gave it to me for five bucks. Kiwi Bruce
Getting hung up all day on smiles
- kiwi Bruce
I found this today, its from Black Swan Cooperage. Interesting. They recommend an inch per gallon for six months. Several different woods available. Kiwi Bruce
From everything Ive read from the industry and my own experiments (isolating end grain vs side grain as the only variable) the end grain imparts a tanic brown paper bag flavor, and side grain imparts a desirable flavor (barrels only have side grain exposure).
Based on my experiments, I would definitely go with the profile on page one of this thread over those last two profiles any day of the week.
- kiwi Bruce
I had to try PR's sticks, here are my copies. Kiwi Bruce
Good to see you guys still looking at my discovery. End grain is not your friend aging wise. Hard to believe this topic is still active, Age on!!!
Good to hear fro you pigroaster! It must be nostalgic looking at a 7 year old thread.
Maybe a dumb question as I am new here, but I have some Staves from a Charred old Bourbon barrell. If cut into pieces would they add anything to something home made, or clear store bought?
Probably so.ptofimpact wrote:Maybe a dumb question as I am new here, but I have some Staves from a Charred old Bourbon barrell. If cut into pieces would they add anything to something home made, or clear store bought?
Read around...there's lots of stories regarding old bourbon barrel staves.
Also, you should read the "spoon feed" thread in my signature too. There is much good info there (hopefully to answer questions like this).
Merry Christmas fellow OAKERS! Patience and time are still the keys to tasting magic liquids!!!
It is good to see so many fans using my method to get good vanilla flavours and better mouthfeel using white oak without getting the end grain harshness. It is almost like using a wooden barrel!!
Thanks for your supportive comments. Brew on and age wisely!
- kiwi Bruce
PR you are welcome! Best whisky I ever aged was using your sticks, one of the best ideas on HD...EVER! Pure genius! Brew on and age wisely!
I should get samples to do quality control! Thanks!
In case you have a killer recipe. Please post it! Or send me a Private message post. Thanks
One thing I haven't seen anyone worry about: oil from your chainsaw contaminating your wood. Worse, I use used motor oil for the chain lube, you can see it left on the cuts.
For me, I'll use a bow saw to re-cut my pieces being used for this purpose and a hatchet to split into fingers.
I would not use a chainsaw to make sticks. My cut off saw removes any saw area that the chainsaw has been near after the logs have been cut. I leave the cut boards outside in the elements for at least a year to weather and get ready. Bow saw would be great tool to use. Funny to see this still active. I just pulled some scotch last night and it was outstanding cut with a splash of water. When I bottle I leave one stick in each bottle.
Right on. I'm just now getting ready to try some aging on oak so I started some reading and a lot of the threads spoke of their cuts of firewood or referenced using the chainsaw and no one expressed concern so I figured I would say something.
Regarding the optimal profile topic of this thread... I wish I had a nice fancy band saw or table saw. Like I said, I'll just be splitting off finger sized splinters using a hatchet. I'm hoping that there is an advantage to the uneven thickness in that I'll get more variations of what will be leeched out.
- kiwi Bruce
Not from the oak alone...split your spirit into three or four batches and age each batch using wood with a different amount of toasting/char, ranging from heavy to moderately light. The spirit will draw different taste tones from each of the woods, now you do a sipping test and blend them together to get the flavors you like. It's predictable and repeatable. Start using a shot class and keep very good notes...spiff wrote: I'm hoping that there is an advantage to the uneven thickness in that I'll get more variations of what will be leeched out.
This is one of the only times that the metric system makes absolute sense...
There are 20 drops in 1 cc
44.5 cc's in a shot (about)
15000 drops in 750 mls
25 one oz shots in a fifth, or 16 regular 1.5 oz shots
the rest is just "do the math" and you'll be able to accurately "up-size" from a shot to a fifth...
Thanks for the tips kiwi.. but I already started on my 6 gallon carboy as a one shot for the batch. I'm not a big whisky drinker either.. this is just for fun and to give away, pretty much.
Speaking of which, is there an optimal ratio of wood to volume? I have about 2 lbs of charred/toasted slivers in the 6 gallon carboy. About 2 fat handfuls of finger sized 6in slivers. It was leeching tannins pretty good the first couple days but tapered off.. its been 2 weeks now and the whole 6 gallon carboy barely has the yellowed darkness of a normal light scotch whiskey, which is what I'm going for, but for a shot glass, not a carboy. So if I suck some up in a turkey baster you can barely see the color. So now I'm wondering if I should just let it ride out with time to continue darkening or if doing so might impart undesirable flavors using so little wood. Not being the whiskey drinker myself, the plan was to get the light golden color I wanted, then rack off to remove the wood and then let age for a year. And let the stilling gods do as they wish with how it turns out.
But now I'm wondering if I'm better off adding more. What lengths of time do you guys usually keep the wood fingers in yours and what ratio's when using the chip in jar method vs barrel aging?
TIA
TIA
