Pigroasters new optimal profile for oak aging sticks
kiwi Bruce
Re: Pigroasters new optimal profile for oak aging sticks
Post by kiwi Bruce »
spiff wrote: I have about 2 lbs of charred/toasted slivers in the 6 gallon carboy. About 2 fat handfuls of finger sized 6in slivers.
The plan was to get the light golden color I wanted, then rack off to remove the wood and then let age for a year.
But now I'm wondering if I'm better off adding more. What lengths of time do you guys usually keep the wood fingers in yours and what ratio's when using the chip in jar method vs barrel aging?
TIA
There isn't a general rule for us to follow at the hobby level...the wood will release it's flavors depending on three factors...the grain of the oak (look at what PR did on the fist page...this exposes the long grain of the oak to the spirit) the amount of char given to the oak. If your oak is only lightly toasted then it can't give you a great depth of color or flavor...you'll need a LOT of oak it this is the case, the the amount of oak used. My oak staves are similar to PR's design, 6" X 1" X 1" cross cut to expose the grain... I use a moderate char and two pieces per quart for six weeks alternating 1 week hot and 1 week in the freezer with a 5 week "Oden's" cold fridge rest at the end, still on the wood, test sipping all the time...BOOM! DONE!
So with your six gal you need 24 of PR's design, 6" X 1" X 1" oak staves... or your equivalent, BUT... I think you may just need more toast on your oak...AND if you take the wood out of the spirit and let it age alone for a year, you'll be very disappointed, leave a couple of used oak pieces in it and the spirit will age nicely.
Have a look at this...viewtopic.php?f=4&t=43367
Getting hung up all day on smiles
Craftdstllr
Post by Craftdstllr »
I also do the three different level of toast/char and blend to taste after aging. I use a syringe that was sold as a turkey injector for measuring the amount of each sample to blend. I am accurate to about 1/4cc. Over time, I have pretty much found the blend I like to be about 3 parts light toast, 3 parts medium toast, and 4 parts heavy toast & charred.
To make life easier, I made a jig for splitting my seasoned oak. It is a steel plate about 1/8" thick sharpened on one side and mounted to a base plate. I hold my chunk of oak over it and pound it with a hammer. I can split a 16 inch diameter log into 3/4 x 3/4 sticks in about 45 minutes.
liqrlkr
Post by liqrlkr »
Good Afternoon. I haven't posted here since some time in 2017. I read your posts all the time and have learned very valuable information from all you fine folks. I am used to my daily foo pahs and mistakes but I did one this week that has me wondering where my brains are sometimes!! I bought a I X 8 X 12' oak board ripped it cut it to length and profiled it all fine and nice. I proceeded to char the oak. About 40 pieces. THEN! I realized it had not made a trip through the oven yet. Dumb and Dumber comes to mind at this point. I had some clear ready to oak ( just 12 quarts) so I decided to throw the charred oak in and see what happens. It has started to color and the little bit of taste that has developed is not bad at all. So has anyone just charred the oak and used it and to what results? Do you supposed it will stink up the house badly if I try to roast them in the oven already charred? Any help in this matter will be greatly appreciated. Thanks. liqrlkr
kiwi Bruce
Welcome back liqrlkr...your confusing yourself...toasting and charring is an either/or situation with your oak, if your looking to toast your oak, then your looking for a mild oak flavor with a lot of caramel and vanilla notes in your spirit, very good for a well made UJSSM. If your looking to char your oak you'll get a more robust taste of the oak with more smokey and leather like tastes, well suited to a good AG bourbon. You haven't ruined your wood by charring it...relax, pour yourself two fingers of your best and be cool! No harm...No foul!
liqrlkr
Post by liqrlkr »
Thank you Kiwi! I have been reading this forum for two years and can't remember this subject coming up. I am now looking forward to trying my spirit with just charred oak. I started out doing NChooch's Bourbon but found the Sweet feed recipe easier and very tasty. It's funny you mention UJSSM because I am waiting for a couple more buckets and I am going to try that recipe too. Thanks again and I will continue reading a maybe participate more. Let ya know in a few weeks how my new found oak turns out!!!
ShineonCrazyDiamond
Post by ShineonCrazyDiamond »
I do not believe, myself, for it to be an either/ or situation. I have always toasted, then charred, but there is nothing wrong with doing it the other way around. It's not going to char the outside anymore.
But since you have so many, why not throw a few in the oven now and report back the difference?
MCH did a whole experiment on toasting and charring, and I believe the agreed upon best practice was a balance of light toast and heavy char? I don't quite remember. But I do know that each variation of charring and toasting gave different results. None of them wrong. Except maybe the mega char acrid jar. :wtf:
1 personal experiment is worth a thousand what if questions :thumbup:
Shine on you crazy diamond."
OtisT
Post by OtisT »
+1 to what SCD said. I personally either toast only or toast then char most of my oak and am happy with the results. I have not done char only, but i know others who do it as a finishing soak and it’s on my list to try. From what I have tasted of this method, it quickly ups the color as well as the char/smoke profile of a bourbon. Should be nothing wrong with a char only. Give it a try. :thumbup: If you like it, it’s good.
Otis
liqrlkr
Post by liqrlkr »
Thanks Otis! The char only has quickly developed color and taste. Can't wait to test in a few weeks. I will keep yall informed on the progress report!!
liqrlkr
Post by liqrlkr »
Well I guess my "charred only" oak is working better than I thought it would. The taste is developing very well and compares nicely with the toasted and charred wood. How many times do you use your sticks? I am on my second use of them and they seem to be working just as good as the first time only maybe a bit slower to color, the taste is still very good though. Thanks.
ShineonCrazyDiamond
I use one new one for whiskey. After that, I use 2 used ones for my rum. There is no third use generally.
pigroaster
Post by pigroaster »
Well Christmas Greetings all you serious aging distillers. Thanks for keeping this post alive. I hope that you all have improved products from reading this long thread.
Old_Brian
Post by Old_Brian »
I love these forums, each of these long rambling threads is a mine of useful snippets that answer some questions, but drive my thirst for more understanding.
A big "Thank you" :clap: to everyone who has offered their thoughts and discussed their methods, I am truly in your debt, for helping me to learn from your experiments, and narrow down the range of experiments I need to do to understand where my preferences in whisky meet the methods available to create them.
T500 boiler, copper dome, with reflux column or Alembic pot still head.
My main aim is to create something like 'Scotch' using grain mashes and aging on oak in glass.
A few videos can be found at my YouTube channel 'Hobby Distiller'.
Post by The Baker »
pigroaster wrote: Mon Dec 30, 2019 11:02 am Well Christmas Greetings all you serious aging distillers. Thanks for keeping this post alive. I hope that you all have improved products from reading this long thread.
I would certainly qualify as seriously aging! And thanks for the Christmas greetings.
liqrlkr
Post by liqrlkr »
Well I just gave the batch of UN toasted charred oak a taste test and indeed it has a milder and sweeter taste than the ones that were toasted AND charred. I was pleasantly surprised with the difference in flavor. I think I will try some toasted only to see the difference. I recently bought 4 ounces of medium French oak chips and added one ounce each to four quarts of clear. I was amazed that after five days it already has developed a good color and in nearly ready to drink. I realize the chips have way more surface area but was very pleased of the flavor in such a short time frame. Just wanted to bring you up to date. Thanks for all the help. liqrlkr
pigroaster
Well it is neat to sit in Fungal on Medeira Island off Portugal escaping from our igloo in Canada to read this. Thanks for posting. Your chips will bite you if you are not careful. Six sticks per gallon is the key. Patience my new friend is the key!i also know in time that straight hearts is not as good as scotch taken near or at 58 ABV after ten years aging! Recap collect in jars before 75 ABV and below 60-62 then small jars. Cover with coffee filters and taste next day. I ovoid heads at all costs. Just taste Johnny Walker and you will know why. Even the gold 90 dollar bottle tastes of heads. You need some tails at the top end to give flavours in time. If you are in a rush keep a hearts batch and it will be fine in a short time but 22 months time makes it shine. The other one will simply get better on sticks all the way. Shake , air and wait!!!!
Sabiki
Post by Sabiki »
I really like your way to maximizing surface area while keeping the distance from the outside surface to the 'center' constant. I am going to try this with some white oak scraps I have. Thanks for the inspiration. I used some 0.004" thick hand plane shavings that I toasted at 385 deg F for 1 hour in 1st batch. Seemed to work OK, I like the color and taste is OK. I like this idea better and will be using in on the next batch.
liqrlkr
Post by liqrlkr »
Good Morning, I would like to follow up on my previous post on the charred but not toasted oak sticks. I just sampled a jar from 4-16-19 and was surprised at the difference in taste. I compared it to a jar from 7-31-20 that was toasted and oaked. The jar that was not toasted had a simple taste like store bought but the jar from July this year was much more flavorful with many other tastes coming out. For my taste buds TOASTING and charring is the way to go!!! Will give it more time and test it again. Thanks All!!!
Thanks for the update :thumbup:
pigroaster
Here we go in 2020. Perhaps we need to char some politicians and make scotch! It is hard to believe that you guys are still reading this series of posts. Stay the course. You will find the holy grail of liquids if you follow this one.
kiwi Bruce
PR I have an oddball question...how did you wind up with a blank line in your profile next to "Last Visited" ?
GreenEnvy22
Post by GreenEnvy22 »
A buddy of mine works at a cabinet factory, early this year he gave me a couple 1"x6"x12" planks. He assures me these have not been treated in any way, just White oak planks they normally used to make cabinet doors.
I left them outside for about 8 months, and today I cut them up into 1 in by 1 inch by 6 inch staves. Tomorrow I'm going to use my table saw to add some grooves to them, then I will toast most of them and also char a couple.
I have a 50L pot still with dual Liebig condenser.
I typically make Whisky, grappa, and brandy.
Do you do them in the oven, BBQ, or torch?
GreenEnvy22
This will be my first toasting. After reading the comments about how much they smoke, I will probably do them in my toaster oven outside.
