DIY wood toasting
DIY wood toasting
Today I had some time and thought I'd dissect a piece of seasoned oak (the common type that grows where I live) and then toast it to varying degrees. I had toasted my wood a few years ago to make a special beer and the remaining one I used for some spirits and I really enjoyed it (both the distillate and the roasting). I only kept the heartwood because it is the most aromatic.
- Swedish Pride
Re: DIY wood toasting
To keep my wife happy if I am toasting I use the BBQ, when charring i use my torch.
I have a small (very old) oven that I modified with a rotating basket and I usually use that. It is true the perfume is wonderful.
This is an old modified oven. On the side you can see the small rotisserie motor that I added, and the basket where it rotates continuously and at low speed. I don't trust that thermostat, so I use it connected to a PID.
This is the lightly toasted oak.
This is a chestnut wood, medium toasted. As you can see, the result is very uniform, the toasting is homogeneous up to the heart of the wood.- jonnys_spirit
Nice toaster! Can it do coffee beans as well?
Cheers,
jonny
Cheers,
jonny
I've never made coffee (sadly!) But I've made a lot of special beans for my beer and it works perfectly. In fact, I built it just for roasted beans and then I found an alternative use for wood, so I think it will work for coffee too.jonnys_spirit wrote: ↑Tue Dec 08, 2020 9:03 am Nice toaster! Can it do coffee beans as well?
Cheers,
jonny
I finished roasting, light and medium side by side.
One question: have any of you ever used almond tree wood? Results?
