Brix. Do I have this correct?
I want to find out how much sugar is in the 8 liters of molasses used in Crow's Rum.
My feed molasses says 82 brix right on the label:
And one degree Brix is 1 gram of sucrose in 100 grams (Wikipedia):
And molasses equals 11.4 kg per an online calculator:
Now to find the amount of sugar in 11.4 kg (8 liters) of molasses at 82 brix, is this math correct?:
(molasses weight / 100 gram) x brix = sugar weight equivalent
(11,400 grams / 100 grams) x 82 brix = 9.348 kg sugar in 8 liters of my deer molasses.
Am I figuring this correctly?
- der wo
Re: Brix. Do I have this correct?
No. To measure the refraction or the specific gravity for calculating the sugar content doesn't work with molasses. Like it doesn't work with roasted grains for example. But still the OG - FG calculator works BTW, both will be a very high number. Doesn't the canister show nutrition facts on the backside? Normally molasses have 45 - 55% sugar. 10kg molasses have fermentable 4.5 - 5.5kg sugar. So in Crows Rum most of the alcohol comes from the added sugar. This is a difference to most commercial Rums, where all sugar is from molasses.
Thank you. No this was an after-thought long after the molasses container was tossed out.
I appreciate your sage comments as I respect your knowledge very much. (And nice to see you hanging around still.)
- rgreen2002
Oddly enough even the Evolved Habitats website does not give you the "nutritional" information. Either the deer don't have a strong enough lobby or the FDA just doesn't seem to care about deer nutrition....yet.
The unfermentables in the Molly will make usable sugar calculations difficult fizzix. Probably why most folks push their SG near 1.1 when making da Rum!
Another "ya git what ya git moment"!
I just dd 2 runs and pushed the Brix between 22-24. Came out right nicely if I do say so myself.
I've had my moments with the Evolved Habitats... I'm a food grade all molly guy now!
HD Glossary - Open this
Thanks rgreen for helping me out with this. The "shoot for 1.1" alone better assists my understanding, too.rgreen2002 wrote:...probably why most folks push their SG near 1.1 when making da Rum!
That’s “priceless”.rgreen2002 wrote:Oddly enough even the Evolved Habitats website does not give you the "nutritional" information. Either the deer don't have a strong enough lobby or the FDA just doesn't seem to care about deer nutrition....yet.
When I’ve used the evolved habits molly, a gallon in 5 gallons of ferment gets me about 1.110-1.120 OG (big!!!). But it finishes around 1.040, so the difference is around 10%ABV potential. It’s tough to “measure” molly because of all the stuff in it, especially the deer lick molasses. There’s a lot of non-fermentable resins in it which produce a coarse flavor when distilled. I had to run it 3x through the still to make it drinkable.
- Skipper1953
The label on my jug says "Total sugars (as invert) 43%".
Hey thanks! Yeah I see my calculation was wa-a-a-y off for all the reasons stated.Skipper1953 wrote:The label on my jug says "Total sugars (as invert) 43%".
- MichiganCornhusker
From Wikipedia:
Degrees Brix (symbol °Bx) is the sugar content of an aqueous solution. One degree Brix is 1 gram of sucrose in 100 grams of solution and represents the strength of the solution as percentage by mass. If the solution contains dissolved solids other than pure sucrose, then the °Bx only approximates the dissolved solid content.
So I guess unless it’s just sugar water it’s meaningless, or at most relative.
I was trying to find a non-sarcastic way of rendering that thought out loud, Michigan, because that's how it now appears to me now.MichiganCornhusker wrote:From Wikipedia:
There's a "cosmological factor" missing (unique to each mixture. e.g. molasses). I'm sticking to proven molasses recipes as this brix thing is elusive to me right now.
A little lot more research may pan this brix thing out. Will have to just rely on the label for "total sugars" for the interim like Skipper1953 showed.
One reference reveals a lot: Brix Ref.1
Likewise this: Brix Ref.2
- rgreen2002
Here is an interesting blurb about Alcohol from Cane Molasses: http://www.sugartech.com/alcohol/molasses.php" onclick="window.open(this.href);return false;" rel="nofollow
And a calculator for checking Alcohol from Cane Molasses: http://www.sugartech.com/alcohol/calculate.php" onclick="window.open(this.href);return false;" rel="nofollow
It uses measurements of tonnes... might be helpful.
I'm not gonna lie....its a little over my head.
Looks like I'll be going up beyond 30 gallon hobby size!rgreen2002 wrote:Here is an interesting blurb about Alcohol from Cane Molasses: http://www.sugartech.com/alcohol/molasses.php" onclick="window.open(this.href);return false;" rel="nofollow
Have a read through this thread
http://www.beekeepingforum.co.uk/sho...tometer&page=2" onclick="window.open(this.href);return false;" rel="nofollow
