Building a Vacuum still with boiling point @ 98°F
Post your builds here.
siko
Post by siko »
Hi you all fellow builders
i am building for a second time in my life a distilling machine. it will be a low temp stills. hoping for a boiling point @97-101°F. :thumbup:
here are some pic of what i have done today :)
please if you have a good idea.... well i love to learn of others :)
here is a pic of the Extended beer keg with th drain, temp probe, and connector to 3kw heating element it is upside down ofc
Keg reddy with temp probe, drain, and 220v 3kw heating element at the bottom :)
with all the parts i need to assebly the column and build the condenser with the coil that i made,
my work bench with all my parts ready for welding
first i start on the condenser #1
3,1/2" pipe and 8mm tube coiled
better hold
better hold
look it is getting there :)
one set of stills done. working on my still number 2.
emptyglass
Location: Victoria, Australia.Usually the shed. Sometimes the cellar.
Re: Building a Vacuum still with boiling point @ 98°F
Post by emptyglass »
Have a look around for some vacuum stills on the site, it might save you a lot of trouble. Theres quite a few issues in building a vacuum still that you may not be aware of. Cuts are hard to do unless your equipment is set up for it, 3kw will be way too much without a controller, and a few other things. :thumbup:
siko
Post by siko »
emptyglass wrote:Have a look around for some vacuum stills on the site, it might save you a lot of trouble. Theres quite a few issues in building a vacuum still that you may not be aware of. Cuts are hard to do unless your equipment is set up for it, 3kw will be way too much without a controller, and a few other things. :thumbup:
yes i know :) been researching a lot and it is my second vacuum still that i build :)
I have a SSR relay 40amps, and pid controler
more update is coming soon :)
Just a thought.
Heating vacuum still to 98f will be easier than at atmospheric pressure.
Cooling the vapors may be a little bit more difficult.
I don't know much about vacuum stills, but I do have a collapsed corny keg from an old experiment.
Edited: nice welding and build siko
frozenthunderbolt
Post by frozenthunderbolt »
interesting.
I'm contemplating a micro (circa 2-4L) Vac still build as i want to recover ethanol after making olive leaf extracts, but don't want to go over 60C max.
skow69
Post by skow69 »
Hello siko. I'm glad to see you back on the forum.
You know this, but I will state it for the benefit of others. If you want your wash to boil around 100f you'll need a vacuum of 27-28 inHg, which equates to external pressure of 13-14 psi.
Looking at your first photo, it's impossible to scale, but that looks like a pretty long section of straight sidewall, i.e. no ribs for strength. You might want to run your specs through this calculator: http://www.gtssnc.com/index.php?option= ... 12&lang=en. Remember the collapse yield is inversely proportional to the diameter after some minimum length. I don't have a formula for that length, but I would guess something like 2 diameters.
Keep posting pics, man. I love to watch your progress.
Skol,
skow
skow69
Post by skow69 »
shadylane wrote:Just a thought.
This is usually one of the first comments made in a discussion of vacuum distillation, that condensing will be a problem. I remember one guy who was convinced that a liebig couldn't possibly be efficient enough to do the job.
The thing is that you can't change the latent heat of vaporization, or liquefaction. So the amount of heat you have to add to change a boiling liquid into vapor is the same regardless of pressure. Likewise, the amount of heat you need to extract for it to condense doesn't change either, so the same condenser you use at atmosphere will do the same job under vacuum.
The limiting factor (for me, at least) is the pressure at which the product boils at room temp. I found, through experience, that point to be about 28 inHg with a 50% ABV output. Now I stay below 27. It's an odd thing to see your product boiling away in the collection vessel.
