Just Post a Pick of your Rig
Post your builds here.
jedneck
Re: Just Post a Pick of your Rig
Post by jedneck » Mon Oct 14, 2019 10:08 am
Lm/vm head on top of 3 plates
big help
Dunder
jedneck
Post by jedneck » Mon Oct 14, 2019 10:11 am
:oops: :oops: Forgot pic
big help
Dunder
Post by shadylane » Mon Oct 14, 2019 10:24 am
Modular stills are He-Man tinker toys :thumbup:
jedneck
Post by jedneck » Mon Oct 14, 2019 10:35 am
:thumbup: big boy legos. Can run pot, 1-5 plates, 32” packed. And lm, vm and or cm. All on a 6, q5 or 30 gallon boiler
big help
Dunder
Twisted Brick
Post by Twisted Brick » Mon Oct 14, 2019 10:55 am
I think of mine as a tubular erector set.
Steam Rig and Manometer
MoonBreath
Post by MoonBreath » Sat Oct 19, 2019 5:52 pm
True Dat ya'll.
Modular concept is also addicting. 😜
CirBeer
Post by CirBeer » Mon Nov 18, 2019 2:00 am
I finished my thumper attachment, looking forward to giving it a run it next weekend.
Novice Distiller, Intermediate Brewer, Expert Drinker!
Lamannamal
Post by Lamannamal » Mon Nov 18, 2019 2:34 pm
Claw hammer 5 gallon with improved 36” Liebig
Texas_T
Post by Texas_T » Mon Dec 02, 2019 2:54 pm
My homemade rig
matjans
Post by matjans » Thu Feb 06, 2020 5:21 am
JacobH
Post by JacobH » Mon Feb 10, 2020 12:16 am
My little pot still. I made this a couple of years ago after a tour of a distillery.
I will be building a column still soon, just waiting for all the parts to arrive :)
Still Water Run Deep
Post by Still Water Run Deep » Sun Feb 16, 2020 10:56 am
May Your Still Waters Run Deep
Justin
VLAGAVULVIN
Post by VLAGAVULVIN » Mon Feb 17, 2020 3:12 am
A beermaker, originally? :roll:
Be safe with the installations like that. Good luck / have fun! :)
Never make banana brandy. And never ferment potatoes: better make banana brandy... Oct.20, 2019
Watching your run is making me lazy (c) James LaBrie
zed255
Post by zed255 » Tue Feb 18, 2020 9:47 am
Decided I needed a smaller still for small batch things like gin or any other experiment that would not be suited to my main keg boiler still. Yes, this has had the requisite cleaning runs performed already...
This is a simple pot still built on, well, a pot. It is composed of a 12qt stainless heavy bottom stock pot and matching lid. I attached a 3" ferrule to the lid simply because it was what I had on hand. A bell reducer a friend made attaches the 2" riser and other parts pictured. The liebig condenser is 36" long and made of 3/4" over 1/2" with a 12ga wire spiral between the pipes. Surprisingly efficient condenser.
I think I will keep my eye out for a suitable SS mixing bowl and go with a domed top, but there seems to be no real issue with the flat lid, it is just more for aesthetics. I have not decided whether to install an internal element or just stay with the induction cook top; I see advantages and disadvantages each way. Yes, my support for the spout end if the condenser is a rifle bipod I wasn't using...
Mmm, Odin's Easy Gin coming off the spout...
Zed
Expat
Post by Expat » Tue Feb 18, 2020 10:21 am
I really like the bipod. Clean looking setup.
Is the acrylic 2 pipe clamp custom? Assuming yes.
Also, could you post a close up of your thermal probe setup?
_____________________
EXPAT
Current boiler and pot head viewtopic.php?f=50&t=71855
Cross flow condenser viewtopic.php?f=87&t=47632
Modular 3" Boka - pics tbd
___________________
zed255
Post by zed255 » Sun Feb 23, 2020 11:36 am
Yes, the bipod will stay. I will make a better mount for it rather than go with zip ties and also drill it internally to make a 45°, stop just because I can.
The acrylic clamp it a quick one I did just to stabilize the supply pipe against the outer shell of the condenser. I will clean it up to make it prettier.
Some added pics. The thermal probe is a DIY one made of an LM35 (degrees centigrade) temperature sensor pressed down into a closed ended 1/4" copper tube with reducer and cap to complete it. The first pic it was not finished and was basically just a copper thermowell. The LM35 outputs 10mV DC for every ℃ change in temperature, so full scale for our purposes 1V DC out at 100℃. I use a simple panel voltmeter with the decimal point set to read out in ℃.
The pressure reducing regulator really improves the usable range of a cheap needle valve, CM guys take note!
Over view. Got a suitable bowl and will be installing a ferrule to switch to a domed top.
Cap with DIY thermal probe.
Inside cap.
Inside cap.
Outside showing connector
Water flow control. Pressure reducing regulator and needle valve.
Zed
Still Learning
Post by Still Learning » Mon May 04, 2020 10:00 pm
BoomTown
Post by BoomTown » Thu May 07, 2020 8:44 am
http://al-ambiq.com/wp-content/uploads/2016/06/4120.png
Hope this shows, I just bought this...anyone ever seen one like it?
BoomTown
Post by BoomTown » Thu May 07, 2020 8:52 am
B5DED0E2-B34B-4333-9F14-8E17A5794676.jpeg.
Well looks there, Ol’ Jed’s all growed up! Gone an built hisself a fancy rig!
Good on you buddy!
Boom
Morning Wood
Post by Morning Wood » Thu May 07, 2020 7:28 pm
Dewstiller
Post by Dewstiller » Fri May 08, 2020 3:58 pm
Not Pictures of my Rigs , Sorry.
Wanted to share though, from 2019. Visited Majorca/Mallorca Spain. Spanish island a little south of the mainland and found this antique, sewing, knitting factory. They had many older "all copper" stills laying around from back in the day. Interesting place.
Stillin-Hearts
Post by Stillin-Hearts » Tue Jun 09, 2020 6:30 am
New setup with an old beer keg. Distilled some water in this pic. Seems to work - for water anyway. Lol.
[IMG]//uploads.tapatalk-cdn.com/202006 ... 29aadc.jpg[/IMG]
Royco
Post by Royco » Thu Jun 11, 2020 8:31 am
Just finished my first electric rig today. Tea urn with a 1200mm Liebig; ss outer with copper 1/2" vapour tube, spiral wound on water side.Testing with vinegar right now. Excited!
No cooling as my wife does not like hosepipes running through the house :roll:
Proper test tomorrow.
I know, I know; bin the thermometer!
Royco
Post by Royco » Thu Jun 11, 2020 8:34 am
Site mod, I took all the pics with the same orientation. Some are rotated 90deg?
ShineonCrazyDiamond
Post by ShineonCrazyDiamond » Thu Jun 11, 2020 9:09 am
Happens.
Shine on you crazy diamond."
whiskymonster
Post by whiskymonster » Sat Jun 13, 2020 1:12 pm
I don't think I ever showed you all the big girl.
2" copper Nixon stone.
Rubberised Bud barrel boiler.
She fills that 4.5l demijohn with 90% in about an hour and a half.
Drinkin, smokin, and tryin ta free my mind
Kegster
Post by Kegster » Mon Jun 15, 2020 4:44 am
She's not pretty & I don't really know what I'm doing. But all my friends say I'm making the best damn whiskey / corn liquor / Apple brandy they ever had?
Reckon even a blind hog finds a nut ever now and then 👍
Cheers 🍸
Master Distiller
Post by still_stirrin » Mon Jun 15, 2020 6:50 am
Rotate it in an app and resave. It likely is the result of the device’s orientation sensor and how you hold the camera, landscape or portrait...horizontal or vertical, respectively.
Here, I did it for you (this time).
The attachment FFC9BBD8-62EA-499B-A3E2-F8BB7D177E39.jpeg is no longer available
Kareltje
Post by Kareltje » Mon Jun 15, 2020 2:26 pm
Cheers 🍸
I like her!
Kegster
Post by Kegster » Tue Jun 16, 2020 2:38 am
Thanks, we really like her too!
