Modular still for the man with little space
Post your builds here
Postby RippoZero » Tue Sep 12, 2017 10:11 am
Made me a new still. the column is made of several tubes with smart flanges. all the gear packs neatly into the boiler for storage. The stillhead is a plated bokakob. The part of the column with packing is 90 cm tall.
Had some wee troubles brazing the stainless flange to the lid of the boiler but i somewhat solved it using two blowtorches. Need to get me something more potent if i'm gonna braze anything in the future. Getting some new flux that might allow me to silver solder to stainless instead.
RippoZero
Re: Modular still for the man with little space
Postby Swedish Pride » Tue Sep 12, 2017 11:17 am
tidy work
Don't be a dick
Swedish Pride
Postby Kareltje » Tue Sep 12, 2017 1:32 pm
Nice, especially when you need a small footprint. :thumbup:
But this still still poses a problem when you need small height. :think:
Storing it all in the boiler is a good idea, by the way.
Kareltje
Postby OtisT » Tue Sep 12, 2017 1:52 pm
Nice small still footprint. It's all the other stuff that takes up my space. ;-)
Cranky's spoonfeeding:
viewtopic.php?t=52975
OtisT
Postby Pikey » Tue Sep 12, 2017 1:58 pm
OtisT wrote:Nice small still footprint. It's all the other stuff that takes up my space. ;-)
What you mean like a couple 50 gallon fermenters and half a dozen 25 litre ones ? Jars sitting about full of oaky stuff ? :lol:
Really nice build though, I went looking for the "Easy flange" thread when I read it as I never could get thick copper wire. Now I find it ! in the uk we're looking for copper ROD or round copper bar !
Thanks for this thread, I've moved on a lot this evening 8)
Pikey
Postby RippoZero » Tue Sep 12, 2017 3:10 pm
Kareltje wrote:Nice, especially when you need a small footprint. :thumbup:
I don't need to use all the tubes. each tube is 30 cm so there are some options there. for stripping runs i just clamp on the still head without any of the tubes.
Ayy this hobby does start to take up space after a while. To make these flanges i used 6mm copper tubing. Measured up the right length plus a few mm. Bend it around the tube I'm going to solder it to and hammer it flat with many light taps. After flattening it i get the ends of the now flattened tubing to fit as best i can i clamp the flattened tubing to the pipe. to make sure everything stays put in the clamp while i solder it i also put in an old cutting disc and a stainless flange. Measure that all the angles are good and solder it up.
Thank you for the praises. You make me blush :oops:
RippoZero
Postby Pikey » Tue Sep 12, 2017 3:23 pm
Yes blush a bit - 8)
I've been looking at 6mm tube as well - cheap if you buy it as "Brake pipe" - twice as much if you buy it as " caravan gas pipe" - and without fittings. :(
Thanks for the lead though because either way it's the least expensive way to go :thumbup:
[Edit - I guess the act of flatting it with many light taps, curls it and makes the outer edge thinner than the inner edge automatically ]
Pikey
Postby goinbroke2 » Tue Oct 24, 2017 8:25 am
Pikey, you can buy copper pipe/tubing labelled for brakes? As in automotive brakes? :esurprised:
If so, wow, that is dangerous! Copper won't handle the 4-6000 lb's of brake pressure which can come in a panic stop or when you hit the brake pedal hard.
Seen it around here many years ago and wouldn't let the guy leave my yard until I swapped out the piece he had for some steel and I bled it etc. Scary stuff!
goinbroke2
Postby Danespirit » Thu Oct 26, 2017 5:43 am
Here around where I live, Cooper pipes for brakeing lines where common. Especially for repairing older cars.
Nowadays, the standart seems to be steel.
So for my reflux coil I just bought a repair kit from the local auto parts shop.
Danespirit
Return to The Construction Site
Who is online
Users browsing this forum: No registered users and 2 guests
