scrapping a freezer to make insulated box
Post your builds here
Postby Pikey » Tue Oct 03, 2017 8:01 am
I have a working chest freezer which is really old. It's been in the garage for 12 years working and I got it for nothing from a guy who was throwing it out 12 years ago, so I'm going to scrap it and hopefully use the sides and lid to make an enclosure for 2x 220 Litre olive barrels to ferment through the winter. I'm wondering whether this would work and how to form corners and joints if i have to cut and join.
The freezer is a 10.5 cu foot chest freezer, stands about waist high. The barrels are a little higher. :?
Pikey
Re: scrapping a freezer to make insulated box
Postby Tater » Tue Oct 03, 2017 8:31 am
just ferment in freezer line with plastic sheet if ya think nessary.
PLEASE READ THIS FORUMS RULES AND THESES Links: http://homedistiller.org and New Distiller Reading Lounge I use a pot still
Tater
Postby Blarney Stoned » Tue Oct 03, 2017 9:53 am
Blarney Stoned
Postby still_stirrin » Tue Oct 03, 2017 10:09 am
You can add an extension above the chest if you need it taller. I’ve seen this done many times with “keezers”, where brewers turn them into kegerators by adding a 2x6 board around the top rim. Insulate it and seal it to the chest. Reattach the top hinge onto your extension. Often brewers add taps in the extension rather than risk damaging the refrigerant coil lines in the chest.
Need a foto? Google “keezer”.
here —> https://www.coldbreakbrewing.com/pages/ ... d-a-keezer
What is a Proof & Traille hydrometer: Alcohol-meter
Enzyme info: SebStar
HD Google search info: HD Google-how to
All about mashing grains: Braukaiser
Master Distiller
Postby NZChris » Tue Oct 03, 2017 10:36 am
I f you wreck it, how are you going to cool it when a rampant ferment overheats?
Master Distiller
Postby Pikey » Tue Oct 03, 2017 11:49 am
Oh bugga :roll:
I spent all day plotting the wall layout with a mate - 2 big fermenters - preheater up high, still lower, thumper, - all sitting in /on / under Dexion racking :D - All I need to do is lose that freezer and insulate the fermenters - Hey wait, I can use the insulated sides etc to box the fermenters in :D ANd still plenty of space for storage on the racking. :) - Got an old incubater I can use as a thermostat controlled heat source :D
Now thanks to you lot, it looks like I have to keep the freezer. I just measured the diameters of the fermenters and it looks as though they "Might just" fit in the freezer - then again knowing my luck it's more likely they "Just won't" :(
But, to make it work, I'll need to miss out one of the front legs. and I suppose when the lid is down I can use the top of the freezer as a workbench, But my storage on the racking is going down and the other equipment will be squeezed - if I can get it in. Actualy I may need to lose 2 complete bays of racking, which will lose a lot of stability :roll:
CAn't get to the freezer at the mo to open it, but I'll give this some more thought tomorrow. I'll give all the ideas a good thought for a while.
As for NZChris's question - I've never had a runaway ferment - Might be nice
Thanks for all your contributions Folks.
Pikey
Postby NZChris » Tue Oct 03, 2017 12:10 pm
Pikey wrote:As for NZChris's question - I've never had a runaway ferment - Might be nice
You've never fermented in a well enough insulated box in summer to have a problem, but with decent insulation it can easily happen. I control the heating elements and compressor with one STC-1000 controller, controlling the temperature in the incubator, not the ferment.
Master Distiller
Postby still_stirrin » Tue Oct 03, 2017 1:13 pm
+1 Chris. Your words were running around in my head.
Master Distiller
Postby Pikey » Tue Oct 03, 2017 2:01 pm
OK lads - point taken - I'll leave the compressor and gas intact, if I can make the dimensions work :thumbup:
[EDit thanks ss - that adaption is now the target ! :thumbup: 8) ]
Pikey
Return to The Construction Site
Who is online
Users browsing this forum: drotto and 2 guests
