Boiler rebuild and new pot head
Post your builds here.
Expat
Post by Expat »
I've been working steadily on rebuilding my boiler, controller and subsequently my pot head condenser needed to be upgraded.
Pot head is 48" of 3/4" over 1/2". Reducing above the sight sight glass, 3" to 2", dropping from 2" to 1" to 3/4" above the riser. Wire wrapped inaode the condenser with a turbulator inside.
Plenty enough to knock down 5500 watts efficiently. During the cleaning run I was able to stabilize knocking down water steam, input was city water @68f, condensed steam @88f and output water @200f. The extra length is really doing its job well.
Completed setup finishing up the cleaning.
Riser and reducer
Water output and flow control
3" column port, 2" Fill port, Sight glass and 3-2 cap reducer
2" element port, element tc adapter, 5500 watt camco ripple fold element.
3/4" drain
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
Expat
Re: Boiler rebuild and new pot head
Post by Expat »
Continuing
Casters, 2" drain port reduced to 3/4" pre valve. Used the original sankey top port.
Updated controller, 220v 30a, SSR and pot. Twist locks are my friend.
Next will be the rebuild of my column to 3".
EXPAT
___________________
Reverend Newer
Post by Reverend Newer »
Love the site-glass in there like that, I'm about to go to 3" myself on the keg pot. 4" for the barrel.
Now is the time for all great men and women to make moonshine !
spiritually taxed circa 1791
Expat
Post by Expat »
Definitely helps to see the passive reflux and catch any puking before it rises.
EXPAT
___________________
Expat
Post by Expat »
Small upgrade to my boiler.
Decided to add a secondary port to my drain outlet so that I can pump backset from the boiler. Much easier than trying to disconnect the pipe from a hot boiler. :D
From the underside.
From the top, connected to my floor drain pipe.
EXPAT
___________________
Nice one expat :thumbup:
Lots of good stuff going on there .
Sunshineer
Location: On a planet in a distance galaxy far far away
Post by Sunshineer »
Love it.
Expat
Post by Expat »
Sunshineer wrote:Love it.
Thanks!
Also, reminded me that I haven't yet posted my updated Boka pics.
EXPAT
___________________
