NNB aka Newbie New build
Re: NNB aka Newbie New build
Updated diagram and draft controller layout thats still work in progress
- Attachments
- Still temps vxxx.pdf
- (2.5 MiB) Downloaded 111 times
- Current Design version 21.pdf
- (1.18 MiB) Downloaded 117 times
Hi all, weekend never long enough but thought Id share some more progress to my build. Finished all column thermowells this evening.
I'll have 15 temperature sensor in total, 11 for the still, but 2 are for RC and shotgun water. 2 are for the boiler and will install them when it arrives but these will be the SS type and not custom. the the last 4 are for the 2 solid state relays and 2 SCR controllers.
More nice work Jason.
Just some food for thought. Those thermowells in the column will cause quite a delay in actual temp readings being reflected in the meters, especially with the air space in them. If you can fine a way to expose your sensors in the column to vapor, with a drip guard, you’ll be a whole lot happier with the results. Just my opinion.
Otis
Otis
The issue he will have with a drip shield is the plastic cable the probes are attached to, best to optimise the thermal transfer by wrapping the probes in copper gauze, the thermowells are copper, so, heat transfer is good, the air gap removal will help.
Cheers
Tony
Cheers
Tony
Hi Guys, not posted for a while as been busy, but my build is nearly done...well I can see the light at the end of the tunnel.
Anyway, some po*n for you all. Enjoy
That is a really awesome looking build mate
I like it a lot bar one easy to fix thing, there's 13 (i assume cheap chinese) electrical modules and numerous switches well within a couple of foot of your product outlet, perhaps an additional stand with some more distance would be safer?
Hi Fred
Thanks for the thought, the box is IP rated, well was as I know I’v made hold for fans etc. I’ll have a think on this.
Glad you like it, and hope my hard work pays off
