Sanke Triclover clamp connection
I'm having a hard time getting my 2" column to seal to the sanke connection on my keg and thumper. I bought a ptfe sanke gasket, but they are two thick and the tri-clamp will not correctly clamp the two pieces together. My column has an "alcohol safe" O ring that fits in the groove on the bottom of the column, but it seams to hit the two notches on the sanke connections where the keg valve was held in, causing it to leak. What are you guys using for this type set up. The ptfe gasket had a raised portion on the both sides, I cut one of them off creating a flat surface for the sanke side.
Re: Sanke Triclover clamp connection
Sand it down to make it thinner. I tried the o-ring long ago, it's not enough surface area to seal easily. If you removed one side but it's still too thick just make it thinner. Note that ptfe is finnicky about making a seal so whatever you sand it with finish with a fairly fine grit to get a smooth surface, and really crank down the tc clamp if you're still having leak issues.
- Twisted Brick
Another solution if you're into building stuff.
Silver Soldering a Tri-clamp Ferrule
I test-fitted a 2" ferrule into the neck of one of my kegs and it slipped inside perfectly. It would take minimal prep work to complete.
As Pope suggested, sand it down. Flat surface and a bit of sandpaper, job takes less than a minute. To add a bit of compression, just give the gasket a wrap in PTFE tape. Done.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
Try putting it together without a gasket......then wrap around the outside with half a dozen wraps of PTFE thread tape.....then put the clamp on and tighten. Used my old keg boiler that way heaps of times ......never a leak.
I ran them on a belt sander last night to make them thinner, clamp fits much better, no leaks during a vinegar run. Hopefully problem solved.
