What do you use to clean a freshly built rig? white vinegar? distilled white vinegar?
Only asking as white and distilled vinegars differ fundamentally in their acetic acid content, and knowing what one to use when cleaning a newly built rig would be handy... I can't be the only person to question this, right? can anyone clarify.
Check below:-
White aka spirit vinegar = 5% to 20% acetic acid content.
White vinegar is sometimes also referred to as spirit vinegar. Contrary to its name, white vinegar is actually clear. It is usually produced from sugar cane, the extract of which is put through acid fermentation. In the process, the liquid is oxidized, causing the chemicals in it to change and become more acidic. Another way of making white vinegar is to combine acetic acid with water. This variation is much sourer than the naturally fermented type; it has 5% to 20% acetic acid content and is considered stronger than any of the other types.
Distilled = 5-8% acetic acid content.
Distilled vinegar, also known as virgin vinegar, can be made from just about any vinegar – for instance: rice, malt, wine, fruit, balsamic, apple cider, kiwifruit, rice, coconut, palm, cane, raisin, date, beer, honey, kombucha, and much more. As its name suggests, this vinegar is distilled from ethanol. ‘Distilled’ plainly means that the liquid component is separated from the base mixture. This produces a colorless solution with 5-8% acetic acid in the water – relatively weaker than white or spirit vinegar.
Cleaning a new build rig
Re: Cleaning a new build rig
I use distilled white, but I don't imagine it makes a huge difference.
I have the correct stuff then
Thanks guys
Thanks guys
what ever vinegar you use , vinegar steam the shit
out of it ... and then ... immediately, rinse the hell out of it with clean water or if nothing else , dump the vinegar and refill the boiler with water and stream. clean the shit out of it ... and then ... rinse the hell out of it with clean water :
If you haven’t got it , I hate vinegar runs . Follow up treatment is essential
or you might be asking questions about bluey green stuff
I too dislike running vinegar but it's a necessary evil for cleaning. I do the same thing, hand wash, fill and run steam through it for a while, then break it down and hand clean everything again. Then at some point do an alcohol sacrificial run. But you don't want to let the still sit after the vinegar run and want to clean it pretty darn well as soon as it cools down enough to work with!
