hybrid fermenter boil kettle
Inspired by content here and necessitated by moving I am converting my brewing rig from natural gas to propane and electric to future proof it. It looks like my new locale will have reasonably priced electricity and I will concentrate on documenting that. Also, I decided to upgrade my sanke fermenter which has also prompted mods to enable its use as my boil kettle. The electric elements will be controlled by a BCS. I hope you don't mind some homebrew tech with so much overlap.
Re: hybrid fermenter boil kettle
Here is my sanke fermenter pre HD:
This started as an ordinary sanke keg I picked up from a scrap yard long years ago. I used a Brewershardware Sanke Fermenter kit. Later I cut the ~8" hole in the top of the keg to be able to get in and really clean. The top was a loose keg top from a keg used as a boil kettle. This was secured with bolts to the nuts you can see on the lid. That never worked well. For a time this was chilled with in a fridge. Later, I purchased a jacketed conical and only use the sanke for larger batch sizes. This was cooled by recirculating the chilled water in a bath/tub made from a rain barrel. (As an aside, getting images usable here on the interwebs was serious pain.)
Here are the latest mods. I had an 8" TC ferrule welded in the top and a 2" TC ferrule welded in the side near the bottom. I can drop a heating element in the 2" port and use directly as a boil kettle. I'll get a pic of the fermenter top. I am still waiting for the 8" TC clamp as it was back ordered.
Very nice. That should do a treat.
- Twisted Brick
Nice job, jward. Clean, versatile rig.
How do you drain it when running electric ?
________________
I will have pictures to follow. I have two options. I can put the fermenter lid on the keg and push the liquid out a racking cane with a bit of pressure through a corny gas QD or I can tilt the keg enough to remove the element and add a valve. The fermenter lid is an 8" TC cap with one 3" and two 1.5" TC ports. While boiling wort it will be open on top. While fermenting the lid is on with the 3" port having a plastic window or a hose barb for a blow off tube. One 1.5 port will have a thermowell. The other 1.5 port can have an hose barb for an airlock or blow off tube, or I could borrow the spudling valve from a different fermenter for fermenting under pressure. Once done fermenting the thermal well can be pulled and a racking cane added. The airlock replaced with a gas QD fitting.
Looking forward to seeing what you do.
I have been busy moving from one coast to the other but finally made it. I had hoped to reveal a special fitting, a loop of CSST welded to a 2"TC used to circulate coolant taking advantage of the bottom 2"TC. The CSST has been too thin and/or not flat enough to weld. I was quite hopeful of the CSST working since I picked up using CSST on this forum. I'll share the new design of a through the top SS coil once I get it.
The previous keg welded photo disappeared. This should be good to go as an attachment. If this work, I think I finally understand how to add photos correctly here.
I have started on the power control parts for the electric elements. I think this is a fairly common approach here using SSRs for power control. Since I have a 240v 30 amp dryer outlet I will use that to provide load protection. In the photo you can see the 10' dryer pigtail go to a 50 amp SPA GFCI panel. I wanted GFCI protection now and may upgrade to 50 amps with a dedicated circuit some day. I decided to use an extension cord cut in two to provide the outlet connected to the controller and the plug connected to the heating element. The first box will hold an amp meter/power meter. The next boxes will each hold the connections for a heating element.
Live fire test went great.
Nice build
Very nice ... but I’m cringing at those SSRs with exposed terminals . Would be nice if they were all in the one box
Very cool! Wow how big is that top Tri-Clamp ferrule? I use a 6", but yours looks a bit bigger.
That is an 8" TC which is the same as on the conical fermentor I use. This will run as a boil kettle and fermentor when I make a larger then ~5 gallon batch or for mead.NineInchNails wrote: ↑Tue Oct 06, 2020 7:17 am Very cool! Wow how big is that top Tri-Clamp ferrule? I use a 6", but yours looks a bit bigger.
To that end another port has been added since I am going electric and want to drain not rack the wort.
