Electric Keggle build
Just got done with my electric keggle to do AG mashes. Had a friend plasma cut the top and then added all the rest myself. Should have put the thermometer higher but it is water tight and does the job.
Re: Electric Keggle build
Looks good! Better than mine. I took an angle grinder to the top. It's functional, but not pretty.
Hope you've got a good stirrer, an element protector, and a pail to empty it with.. that small valve will give problems in emptying a mash..
Mars
Mars
– Albert Einstein
– Albert Einstein
Actually going to be doing big BIAB with a false bottom I don’t have in there in the picStillerBoy wrote: ↑Thu Aug 20, 2020 3:56 pm Hope you've got a good stirrer, an element protector, and a pail to empty it with.. that small valve will give problems in emptying a mash..
Mars
Nice. If it's an option, a rope and pulley attached to the ceiling will make life easier with biab. It gets heavy and the easiest way is suspending it above the kettle for a while.
I’ve already got one hung from the ceiling from brewbag along with their keggle BIABA
With false bottom
Pulley system
My nephew has a pulley like that to drain his grain; but it is mounted on a gantry so he can
pull it aside to drain into the boiler or whatever.
