Sourcing for TriClamps?
I’ve upscaled my rig to using 1 ¼” copper tubing and want to use Tri-Clamps for the joins. Does anyone even make these? If so who, and how can I contact them?
- Deplorable
Re: Sourcing for TriClamps?
Have you checked Glacier Tanks?
+1 to glacier tanks
Stainless pot with copper shotgun I'm a simple kind of guy
Damn try going to 2 inch then I know they have those
Show your equipment I'd say solder it together then and use unions to make it a little modular
search "sanitary fittings" or "Dairy fittings" on the net and you will find
many more than one supplier out there. I've found from 1/4" - 16" pipe size.
- Stonecutter
You could trying hitting up food processing plants. They have nothing but tri-clamp fittings and SS equipment. I did some work inside of a local protein bar manufacturer that was upgrading their facility and that kinda sh*t was laying around everywhere.
I’m not too sure how you would go about getting in touch with those kind of folks but it’s worth a shot.
-Thomas Paine
-Thomas Paine
Product and shipping prices vary widely for sanitary fittings.
With a little shopping, you will find lots of sources.
Keep an eye out for how long to be delivered.
Price of product
Price of shipping / import fees
Best prices will almost always be from china.
Price of product
- Deplorable
A simple search on Amazon turned up these in under 30 seconds
- Windy City
I use 1 1/4” copper on some of my equipment.
I take a 1 1/2” stainless ferrule and machine out the id slightly to allow soldering
1 1/4” pipe inside. Before I found a great machinest that would do all my custom work I would just sand down the pipe and heavily sand the ferrule so that it would fit.
Then all you need is the standard 1 1/2” triclamp
Hope this helps
Hope this helps
- Windy City
- Windy City
This is my return for my 4 plate side column.
I am about to put my barrel and a half brewery back together and plan on using this extensively.
I had 20 ferrules milled out for about $100
This is a glacier tanks 1.5” on a piece of 1.25” copper pipe. No machining required for mine. Slip fit is about perfect for a solder join.
- Windy City
Awesome
Wow! That’s exactamemtae what I need, and that works to a 1 ½” tri clamp?
I have used unions in past rigs, they worked fine, but this situation is space confined and the tri-clamps are a better fit. And then there is the difference in the costs. Unions are lots more expensive per joint, But Thankyou for your thoughts.
I bought the 1.5” ferrules, am excited that this might work. Thanks for your thoughtsWindy City wrote: ↑Sun Apr 18, 2021 3:47 pm I use 1 1/4” copper on some of my equipment.
Hope this helps
- Windy City
No problem, happy to help
Hope it works out well for you
