Sourcing for TriClamps?
Post your builds here.
BoomTown
Post by BoomTown »
I’ve upscaled my rig to using 1 ¼” copper tubing and want to use Tri-Clamps for the joins. Does anyone even make these? If so who, and how can I contact them?
Deplorable
Re: Sourcing for TriClamps?
Post by Deplorable »
Have you checked Glacier Tanks?
Not sure
Post by Not sure »
+1 to glacier tanks
Stainless pot with copper shotgun I'm a simple kind of guy
BoomTown
Post by BoomTown »
Not sure wrote: Sun Apr 18, 2021 11:28 am +1 to glacier tanks
Just did a quick search at their website, zero items discovered...
Not sure
Post by Not sure »
Damn try going to 2 inch then I know they have those
BoomTown
Post by BoomTown »
Not sure wrote: Sun Apr 18, 2021 12:04 pm Damn try going to 2 inch then I know they have those
I’m locked in at 1.25” copper, and have limited space
Not sure
Post by Not sure »
Show your equipment I'd say solder it together then and use unions to make it a little modular
cob
Post by cob »
BoomTown wrote: Sun Apr 18, 2021 12:05 pm
search "sanitary fittings" or "Dairy fittings" on the net and you will find
many more than one supplier out there. I've found from 1/4" - 16" pipe size.
Stonecutter
Post by Stonecutter »
You could trying hitting up food processing plants. They have nothing but tri-clamp fittings and SS equipment. I did some work inside of a local protein bar manufacturer that was upgrading their facility and that kinda sh*t was laying around everywhere.
I’m not too sure how you would go about getting in touch with those kind of folks but it’s worth a shot.
-Thomas Paine
tiramisu
Post by tiramisu »
Product and shipping prices vary widely for sanitary fittings.
With a little shopping, you will find lots of sources.
Keep an eye out for how long to be delivered.
Price of product
Price of shipping / import fees
Best prices will almost always be from china.
Deplorable
A simple search on Amazon turned up these in under 30 seconds
Windy City
Post by Windy City »
I use 1 1/4” copper on some of my equipment.
I take a 1 1/2” stainless ferrule and machine out the id slightly to allow soldering
1 1/4” pipe inside. Before I found a great machinest that would do all my custom work I would just sand down the pipe and heavily sand the ferrule so that it would fit.
Then all you need is the standard 1 1/2” triclamp
Hope this helps
Windy City
Windy City
This is my return for my 4 plate side column.
I am about to put my barrel and a half brewery back together and plan on using this extensively.
I had 20 ferrules milled out for about $100
30xs
Post by 30xs »
This is a glacier tanks 1.5” on a piece of 1.25” copper pipe. No machining required for mine. Slip fit is about perfect for a solder join.
Windy City
30xs wrote: Sun Apr 18, 2021 5:32 pm F5252F15-0B32-47AE-800F-AFAB80743C79.jpeg
Awesome
BoomTown
Post by BoomTown »
Wow! That’s exactamemtae what I need, and that works to a 1 ½” tri clamp?
30xs
Post by 30xs »
BoomTown wrote: Mon Apr 19, 2021 11:16 am
Glad I could help.
Yes 1” and 1.5” ferrules use the same clamp, just different gaskets.
BoomTown
Post by BoomTown »
30xs wrote: Mon Apr 19, 2021 2:55 pm
Glad I could help.
Placed my order just now. Thanks again!
BoomTown
Post by BoomTown »
Not sure wrote: Sun Apr 18, 2021 12:14 pm Show your equipment I'd say solder it together then and use unions to make it a little modular
I have used unions in past rigs, they worked fine, but this situation is space confined and the tri-clamps are a better fit. And then there is the difference in the costs. Unions are lots more expensive per joint, But Thankyou for your thoughts.
BoomTown
Post by BoomTown »
Windy City wrote: Sun Apr 18, 2021 3:47 pm I use 1 1/4” copper on some of my equipment.
Hope this helps
I bought the 1.5” ferrules, am excited that this might work. Thanks for your thoughts
Windy City
BoomTown wrote: Tue Apr 20, 2021 1:55 am
No problem, happy to help
Hope it works out well for you
