Gravity & Temperature Compensation Calculator
fizzix
Post by fizzix » Thu Oct 04, 2018 4:11 pm
If you don't have a handy gravity/temp calculator,
you may want to save this one in My Favorites.
Simple entries, instant calculation.
hpby98
Re: Gravity & Temperature Compensation Calculator
Post by hpby98 » Thu Oct 04, 2018 6:06 pm
Good to know
I also built it into my spreadsheet tracker, if you want to see the calculations
viewtopic.php?f=1&t=69958
fizzix
Post by fizzix » Thu Oct 04, 2018 11:29 pm
Nice work, hpby98.
The talent assembled here blows me away.
hpby98
Post by hpby98 » Fri Oct 05, 2018 5:24 am
fizzix wrote:Nice work, hpby98.
Thanks. I like to play somedays and knowing how washes usually progress helps me estimate better.
I also suggest a set of alcohol meters calibrated to 20c, as that’s what correction tables have been released for, although I did another spreadsheet I should finish for that.
https://www.ebay.com/itm/10PCS-High-pre ... 2439154858" onclick="window.open(this.href);return false;" rel="nofollow
8Ball
Post by 8Ball » Sat Jun 08, 2019 3:12 pm
Mine is calibrated at 60F, adding/subtracting 0.002 for every 12.4 degrees delta.
So, I do this:
Actual temp - 60 = Delta
Delta divided by 12.4 = correction factor
Correction factor times 0.002 = amount to add to initial reading
Example:
SG 1.004 @ 88.4F
88.4-60=28.4
28.4 divided by 12.4= 2.290
2.290*0.002= 0.00458
1.004+0.00458= 1.00858
Your temperature corrected SG is 1.009
Or you can just stick yer finger in it and taste it.
8B
The struggle is real and this rabbit hole just got interesting.
