Gravity & Temperature Compensation Calculator
Research sources, reviews and links to information relating to distillation.
fizzix
Post by fizzix »
If you don't have a handy gravity/temp calculator,
you may want to save this one in My Favorites.
Simple entries, instant calculation.
hpby98
Re: Gravity & Temperature Compensation Calculator
Post by hpby98 »
Good to know
I also built it into my spreadsheet tracker, if you want to see the calculations
viewtopic.php?f=1&t=69958
fizzix
Post by fizzix »
Nice work, hpby98.
The talent assembled here blows me away.
hpby98
Post by hpby98 »
fizzix wrote:Nice work, hpby98.
Thanks. I like to play somedays and knowing how washes usually progress helps me estimate better.
I also suggest a set of alcohol meters calibrated to 20c, as that’s what correction tables have been released for, although I did another spreadsheet I should finish for that.
https://www.ebay.com/itm/10PCS-High-pre ... 2439154858" onclick="window.open(this.href);return false;" rel="nofollow
8Ball
Post by 8Ball »
Mine is calibrated at 60F, adding/subtracting 0.002 for every 12.4 degrees delta.
So, I do this:
Actual temp - 60 = Delta
Delta divided by 12.4 = correction factor
Correction factor times 0.002 = amount to add to initial reading
Example:
SG 1.004 @ 88.4F
88.4-60=28.4
28.4 divided by 12.4= 2.290
2.290*0.002= 0.00458
1.004+0.00458= 1.00858
Your temperature corrected SG is 1.009
Or you can just stick yer finger in it and taste it.
8B
