CCVM Questions
CCVM Questions
Hello Everyone,
I am a new guy here, thanks for letting me in. I have been reading and collecting info for about 6 months now and I'm ready to build my first still. I want to build a CCVM still. I do have 2 questions tho. With everything I've read I can't seem to get an honest answer or a non conflicting answer.
#1. On the colum of a ccvm still, is it necessary to make the tee and the arm going to your condenser the same size as the colum?
#2. What is the formula to figure out what size colum to build ? I understand that boiler size, heat input, height and diameter all figure into this but what is the formula to figure it out?
Looking for any help you guys can give, I'm excited to start building. Thanks again.
Re: CCVM Questions
No, assuming you don’t want to fraction with a 1:1 reflux ratio. I don’t know anyone who does that. I run a 1” output on a 3” column and a 3/4” outlet on my 2” column and never have I opened the valve all the way when fractioning. That is just my experience. Maybe someone will chime in with a reason to run with a lower reflux ratio.cathousemouse wrote: ↑Tue Sep 08, 2020 6:44 pm #1. On the colum of a ccvm still, is it necessary to make the tee and the arm going to your condenser the same size as the colum?
If/when you run that column like a pot still you will need to cap the top so the increased pressure will force all the vapor out the vapor port, so a smaller opening is not a problem when pot stilling with it.
Tougher to answer wiithout knowing more about your goals. To figure this out, I usually start by asking how much product do you want to make, and what kind of product? (Example, is your goal to fill 5 gallon barrels, or maybe just a gallon to age in jars? Neutral or brown spirits? Gin?) From there it’s a matter of how much time you want to spend doing it. (For instance, you can make a lot by doing one big batch or many small batches. You could process 10 gallons in 3 hours or 15.).cathousemouse wrote: ↑Tue Sep 08, 2020 6:44 pm #2. What is the formula to figure out what size colum to build ? I understand that boiler size, heat input, height and diameter all figure into this but what is the formula to figure it out?
If you already know some of your constraints, that will help narrow this all down. Examples: are you settled on using a 15 gallon keg boiler, or do you have flexibility on the size? Gas or electric? If electric, Can you run 220v or just 110V ( or multiple circuits?). Do you have 8’ ceilings, or 12’.
Otis
Re: CCVM Questions
I run a 2” CCVM. The column and offtake are both 2”. It has 1.2 metres packed column (SST potscrubbers). I get an output of 1.2 litres per hour at 95% at around 1450 Watts on 240 VAC. There’s a photo of it in the link below VVV
Modular 2" Pot Still
Re: CCVM Questions
In the early VM days , trying to achieve 1:1 reflux was considered a goal .... pointless really. ... when you consider that VMs were mostly used to achieve close to Azeo .But it was a new design and trying to push its limits in both directions to make it as versatile as both a stripper and a Neutral still were the aim.Thats why there was an obsession with using an equal Tee . The problem is that a large stainless valve was and still is ridiculously expensive .
That is why the VMs with dual reducers appeared . One could then use a smaller valve but achieve the 1:1 refux .
The reality struck nearly everyone that operated a VM that A 1:1 reflux was never really needed and that the valve was normally only barely cracked open . Most had a seperate pot still for stripping anyway .
Folk soon started to use a valve about 1/4 the diameter of the column and achieve the high AVB they were chasing with less fiddly adjustment .
Now along comes CCVM .... no valve required .
As equal Tees are readily available , the use of them become popular again . Not for the purpose of achieving 1:1 reflux , but because it was easier to build .
Also there is a second side effect of using an equal tee on CCVM .... and that is that the larger takeoff port size makes the range of adjustment less critical due to there being a bigger area to have to lift the condenser across .
- bluefish_dist
Re: CCVM Questions
Looks like takeoff size has been pretty well covered. My experience is much the same 1:1 is not needed.
Sizing is really based on how much you want to make and how fast. 2” will make 1l per hour 3”, 2l per hour and 4” 4l per hour. They also need power to match, 2” needs about 1800w, 3” needs about 3000w and 4” needs about 6000w.
Boiler size needs to be matched to column size. Too big a column on a small boiler and the column holds all the alcohol. Too small and you spend 12-16 hrs doing a run. Take your hrs from start to finish you are willing to spend, then Take off 1.5 hrs for warmup and equalization. The rest is output time. So for 4.5 hrs, you have 3 hrs of production time. With a 2” you will get 3l, 3” will do 6 and 4” will do 12l. From a 10% wash that’s 30l for a 2”, 3” needs 60l, and 4” Needs 120l of wash. It will actually take longer as the takeoff rates do slow down during a run, but it will give you an idea of how it will all work.
Formerly
Dsp-CO-20051
Dsp-CO-20051
Re: CCVM Questions
I enter on this point to ask you for advice: for a mini boiler with 15 liters of low wines which maximum column diameter would you use? It seems like only me running small quantities ... thank you very muchbluefish_dist wrote: ↑Wed Sep 09, 2020 7:13 am Looks like takeoff size has been pretty well covered. My experience is much the same 1:1 is not needed.
Re: CCVM Questions
What happens if you are undersized on power? I have a 10gal 2800W boiler. Would you recommend a 2" or 3" column?Sizing is really based on how much you want to make and how fast. 2” will make 1l per hour 3”, 2l per hour and 4” 4l per hour. They also need power to match, 2” needs about 1800w, 3” needs about 3000w and 4” needs about 6000w.
Re: CCVM Questions
1:1 reflux ratio will give you highest output rate. Probably not an issue with the 3” and above columns but becomes a consideration with smaller columns.
- bluefish_dist
Re: CCVM Questions
I would go with 3” if you can afford it. 2800w will run a 3” just fine and it will have almost double the output of a 2”.Sk8brew wrote: ↑Wed Sep 09, 2020 11:55 amWhat happens if you are undersized on power? I have a 10gal 2800W boiler. Would you recommend a 2" or 3" column?Sizing is really based on how much you want to make and how fast. 2” will make 1l per hour 3”, 2l per hour and 4” 4l per hour. They also need power to match, 2” needs about 1800w, 3” needs about 3000w and 4” needs about 6000w.
Formerly
Dsp-CO-20051
Dsp-CO-20051
- bluefish_dist
Re: CCVM Questions
I would go 2” or 3” if all you are doing is low wines. 3” would be better. 15l at 40% is 6l of alcohol. That’s probably 6-8 hrs on a 2” and 3-5 hrs on a 3” that’s after warm up and stabilization.Demy wrote: ↑Wed Sep 09, 2020 9:36 amI enter on this point to ask you for advice: for a mini boiler with 15 liters of low wines which maximum column diameter would you use? It seems like only me running small quantities ... thank you very muchbluefish_dist wrote: ↑Wed Sep 09, 2020 7:13 am Looks like takeoff size has been pretty well covered. My experience is much the same 1:1 is not needed.
Formerly
Dsp-CO-20051
Dsp-CO-20051
Re: CCVM Questions
Thanks so much. So is it possible to use large columns in small kettles? I've always seen here that the reference to columns is always for larger quantities (usually starting from 5 gallons to go up) so I have a lot of difficulty in finding information on my small quantities. I've been using a 1.5 "VM column for a couple of years and was thinking of upgrading to a 3" column but can't find any supporting info.bluefish_dist wrote: ↑Wed Sep 09, 2020 7:29 pmI would go 2” or 3” if all you are doing is low wines. 3” would be better. 15l at 40% is 6l of alcohol. That’s probably 6-8 hrs on a 2” and 3-5 hrs on a 3” that’s after warm up and stabilization.Demy wrote: ↑Wed Sep 09, 2020 9:36 amI enter on this point to ask you for advice: for a mini boiler with 15 liters of low wines which maximum column diameter would you use? It seems like only me running small quantities ... thank you very muchbluefish_dist wrote: ↑Wed Sep 09, 2020 7:13 am Looks like takeoff size has been pretty well covered. My experience is much the same 1:1 is not needed.
Re: CCVM Questions
What size of boiler do you have? Personally I wouldn't put a 3" column on anything smaller than a 15 gallon/~50 liter boiler.Demy wrote: ↑Wed Sep 09, 2020 11:28 pmThanks so much. So is it possible to use large columns in small kettles? I've always seen here that the reference to columns is always for larger quantities (usually starting from 5 gallons to go up) so I have a lot of difficulty in finding information on my small quantities. I've been using a 1.5 "VM column for a couple of years and was thinking of upgrading to a 3" column but can't find any supporting info.bluefish_dist wrote: ↑Wed Sep 09, 2020 7:29 pmI would go 2” or 3” if all you are doing is low wines. 3” would be better. 15l at 40% is 6l of alcohol. That’s probably 6-8 hrs on a 2” and 3-5 hrs on a 3” that’s after warm up and stabilization.Demy wrote: ↑Wed Sep 09, 2020 9:36 amI enter on this point to ask you for advice: for a mini boiler with 15 liters of low wines which maximum column diameter would you use? It seems like only me running small quantities ... thank you very muchbluefish_dist wrote: ↑Wed Sep 09, 2020 7:13 am Looks like takeoff size has been pretty well covered. My experience is much the same 1:1 is not needed.
With your 1.5" VM, have tried different packing? Some packings allow faster speeds, although not alot, while achieving just as high abv% and separation
Re: CCVM Questions
I have 3 small boilers of 10L, 15L and 30L respectively. Initially I built a VM column because I was given the tube of this size and I believe it is suitable for small sizes, then I wondered how far the diameter of such small boilers could be increased. I use a pack of scrubber, I feel very comfortable. Thank you very much for your intervention, any advice is well accepted.hellbilly007 wrote: ↑Sun Sep 13, 2020 3:59 pmWhat size of boiler do you have? Personally I wouldn't put a 3" column on anything smaller than a 15 gallon/~50 liter boiler.Demy wrote: ↑Wed Sep 09, 2020 11:28 pmThanks so much. So is it possible to use large columns in small kettles? I've always seen here that the reference to columns is always for larger quantities (usually starting from 5 gallons to go up) so I have a lot of difficulty in finding information on my small quantities. I've been using a 1.5 "VM column for a couple of years and was thinking of upgrading to a 3" column but can't find any supporting info.bluefish_dist wrote: ↑Wed Sep 09, 2020 7:29 pmI would go 2” or 3” if all you are doing is low wines. 3” would be better. 15l at 40% is 6l of alcohol. That’s probably 6-8 hrs on a 2” and 3-5 hrs on a 3” that’s after warm up and stabilization.
Re: CCVM Questions
1.5" is good for the boilers you have. 2" would work as well, although I wouldn't see it worthwhile to upgrade to 2". The slight increase in speed wouldn't be much.
- bluefish_dist
Re: CCVM Questions
[/quote]
[/quote]
[/quote]
Really a larger column on a small boiler only works on low wines. I ran a 6” on a 30 gallon boiler. But that same setup would not work over wash or wort. Simply too big for the amount of alcohol present. To get 15l of low wines you had to strip 60l or more of wash/wort so it’s really like you are running a larger boiler by only running low wines. Go for the 3”.
[/quote]
[/quote]
[/quote]
Formerly
Dsp-CO-20051
Dsp-CO-20051
Re: CCVM Questions
Thank you very much, it is the most concrete answer I have had on this topic.hellbilly007 wrote: ↑Mon Sep 14, 2020 6:10 am 1.5" is good for the boilers you have. 2" would work as well, although I wouldn't see it worthwhile to upgrade to 2". The slight increase in speed wouldn't be much.
Re: CCVM Questions
Looking at building a CCVM.
I have both four inch and two and a half inch copper tube.
I can go to about 1500mm in column length to the underside of the tee.
Boiler is 50L with 4" take off, heated by LPG.
The question is, is it ok to build the column with half four inch and the other half in the two and a half inch making up the 1500mm.
I've searched regarding my question and have not found columns built from 2 different diameter tubes, 3" seems to be the way to go for boiler size which is why with the tubing i have at hand my thinking was to combine the two different diameters.
Just asking the question before i commit to building something which is not going to work??
- bluefish_dist
Re: CCVM Questions
You can use both size pipes, but the output will be limited by the smaller of the two. The only reason to do it would be you have it on hand and can’t afford to buy more of the bigger diameter.
Formerly
Dsp-CO-20051
Dsp-CO-20051
Re: CCVM Questions
Ok that answers my question build either 4"or 2.5".
I have enough material of both sizes, so back to do more reading!!
Re: CCVM Questions
A little more reading and have settled for the 2.5" column. Thank's Bluefish for the advice.
Re: CCVM Questions
Probably a good decision tas , although 4” sounds the go, there are a whole lot of issues that go with it such as extra heat , cooling , bigger boiler size etc . Not to mention the height of it .
Re: CCVM Questions
Yummyrum, Yes after reading a few more posts on CCVM builds for my use the 2.5" will be more than enough.
Re: CCVM Questions
2.5 will be a whole heap better than 2 inch......3 would be better if you could find some.......as Yummy says .....4 will be a whole new ball game and cause more trouble than its worth probably.
Re: CCVM Questions
I would go 2” or 3” if all you are doing is low wines. 3” would be better. 15l at 40% is 6l of alcohol. That’s probably 6-8 hrs on a 2” and 3-5 hrs on a 3” that’s after warm up and stabilization.bluefish_dist wrote: ↑Mon Sep 14, 2020 6:39 am I enter on this point to ask you for advice: for a mini boiler with 15 liters of low wines which maximum column diameter would you use? It seems like only me running small quantities ... thank you very much
[/quote]
[/quote]
[/quote]
Thank you very much, yes in any case I do a stripping and then a second distillation precisely because of the small amount. If I am not mistaken do you suggest a 3 "column also on 15 liters of low wines? Could it also work on 10L? Thanks in advance.
Re: CCVM Questions
So I'm looking to build a CCVM. Originally I was going to go with a 2", but after reading this and other threads I'm thinking of upping it to 3". Q1, I'm using a 15 gal keg as the boiler and it has a 2" output. Will the 3" "still" be better or not? Q2, I was thinking of making 5-7 gals of mash at a time and if I put that in the boiler would a 3" make a significant difference. Thanks
- DasBeast007
Re: CCVM Questions
Use a 3x2 reducer (I use a short reducer to keep the overall height down). If you place the reducer at the keg and then go 3" you can take advantage of the 3" column's speed.
My 15 gal is used to strip 10 gallon batches or to reflux a NGS. I have a smaller 7 gallon keg that I use for most of the 5 gal or less batches. In potstill mode on a spirit run I don't believe you would see much difference between the two sizes. Those runs are meant to be low and slow.
2" CCVM on a 7.5gal keg boiler
3" CCVM on a 15.5 gal keg boiler
hardly used...Pot Still all-da-time
Re: CCVM Questions
Make sure you've got a ladder she'll be tall if you go three inchcmac62 wrote: ↑Thu Sep 23, 2021 1:45 pm So I'm looking to build a CCVM. Originally I was going to go with a 2", but after reading this and other threads I'm thinking of upping it to 3". Q1, I'm using a 15 gal keg as the boiler and it has a 2" output. Will the 3" "still" be better or not? Q2, I was thinking of making 5-7 gals of mash at a time and if I put that in the boiler would a 3" make a significant difference. Thanks
Re: CCVM Questions
I thought it could be less tall if I used the 3".
Re: CCVM Questions
For one run and done neutral spirits.
A rough guesstimate is to have a column 20 times taller than it's diameter.
Taller than that is beginning to get into diminishing returns.
Personally, I think two runs, is better than one run in taller column.
Long story short, I'd strip first, dilute and run it again.
Re: CCVM Questions
Agree with Shady .
