Tools For The Trade
Tools For The Trade
Thought a thread of any helpful hints would be handy .A drill powered morter mud mixer Heres what I use to mix my washes I sharpened edges into blades to help when using fruits works great. http://www.contractorsdirect.com/Tile-T ... uick-Mixer" onclick="window.open(this.href);return false;" rel="nofollow
I used a ripped up wet white t-shirt impregnated with wet flour paste untill I reduced the gap size betweeen my boiler body and cap.
It took many times of using unsuitable gasket materials before I stumbled onto this method. Joining this forum sooner would have helped speed up the learning process also.
Thought this was kinda nice for those of you that want the best of everything... A nice little grinder review site; gives results, and torque and all the techy info.
http://waltonfeed.com/self/grind3.html" onclick="window.open(this.href);return false;" rel="nofollow
might be a little hard to find the items on the site for good prices but hey its an option I guess.
According to that chart that Victoria grinds like Whoa....!
DAMN NUMBERS!!!
DAMN NUMBERS!!!
Thats a great link... I wish I had found that while I was looking into grinders... but, whoa? how do you quantify that?
It grinds fine for what we do...If you read that chart you'll see that it grinds one cup in 27 seconds. The next best is one cup in 2:13...talk about whoa... I can tell you thats finer than you need for what we're doing so thats really about half the volume you can grind in half a minute. Don't let that 18 pound force intimidate you Don, you can probably use the exercise. I filled two 6.5 gallon buckets a few days ago with it and it's a workout...25 bucks at the gym would do me no better.
Speaking of which, check this out:junkyard dawg wrote:I filled two 6.5 gallon buckets a few days ago with it and it's a workout...25 bucks at the gym would do me no better.
http://www.countrylivinggrainmills.com/country7.html" onclick="window.open(this.href);return false;" rel="nofollow
Dane Cook
Dane Cook
LOL sorry man sometimes I forget that my "ebonics" doesn't come out very well in text. "like whoa!" is more of "Damn thats bad ass!!"junkyard dawg wrote:...but, whoa? how do you quantify that?
I was saying that becuase it has the highest output rate of all the other grinders, and although it does require more torque to opperate, I'm not against using a fair bit of elbow grease!
Cmon man take everything with a grain of salt. No harm, No foul homie.
DAMN EBONICS!!!
I was looking for the tolerance specs on the different types of Tri Clover gaskets.
Found thier website. This should be the link to the distilling part.
http://www.alfalaval.com/ecoreJava/WebO ... guageID=62" onclick="window.open(this.href);return false;" rel="nofollow
There is a lot of good reading there.
Cheers
Cheers
You bring the fair maidens, I'll bring the panty-remover.
I'd rec the Valley Grain Mill from Ontario, canada.
http://www.web.ca/~valley/valleymill.html" onclick="window.open(this.href);return false;" rel="nofollow
You can adjust the grind by adjusting the clearance of the wheels and they give ya plan to hook it up to a drill or a belt driven motor.
BR
BR
Old electric coffee grinder...
A few days ago, in my mother's cellar, I found an old electric coffee grinder... The date of purchase is still written on the box : 09/11/1974!
Today, I tried to grind barley malt with it and it works pretty good!
It allows me to grind 100 g at a time.
I'm french speaking!
these boy i no ben handed down a 3/4 ss pipe they cut to length an whitled peace of oak for stoper in one end wedged tite to stay an they cut a ole felt hat to make plug for other end. aint no tellin how old that tester is an it aint had a easy life. this one got a round end so it can check gal jugs not chug to the brim full . it come from a farmacy for makein
medisines way back when.
so im tole
so im tole
Re: Tools For The Trade
i just got one of these for $4 from the hardware and its great to clean out the condenser and any other 1/2" copper.. i had to bend the little loop in the end of the brush straight part from that she works a treat
1974 doesn't make it old.
blanik
blanik
Cumudgeon and loving it.
suppose it's relative... I'm going to apply the "it's older than I am, and therefore can be referred to as 'old' in general" mentality and say that it IS old... especially for a little doodad like that.
HELP! I am looking for a mixer to chuck up in a cordless to use in a 6 gallong glass carboy. the problem I am encountering is the diameter... been to good old Home D. In the paint department they have this great squirel cage mixer for a drill but the issue is diameter. My carboy has a diameter of about 1 1/8 inch (about 3 cm, seeing as this is a global bunch). I thought about trying a piece of round stock stainless and trying to put a couple of bends/kinks in it, sure would cavitate but not sure of any real mixing getting done? Any ideas?
check this out you could make one--- http://pivo.northernbrewer.com/nbstore/ ... r&x=34&y=9" onclick="window.open(this.href);return false;" rel="nofollow
did not come out for some reason #@@$%
http://pivo.northernbrewer.com/nbstore/ ... &x=31&y=12" onclick="window.open(this.href);return false;" rel="nofollow
looks like I did it this time????
Thanks Dnderhead, that looks like it will fit the bill..
ok, new issue! Either I have a bad alcoholmeter or I live in the best place! Used my new alcoholmeter for a coupe stripping runs and was about to cut for a spirit run and realize my tap water is 20% ABV! Not sure how a hydrometer goes bad? Any one have any simular problems?
Sounds like ya got a bad one. Hold it by the bulb end and flick it like an old fashion thermometer. Bet the scale is moving around.
Temperature of water?
Temp of water is 20c. Hawke, tried shaking the hydrometer and i dont see it moving... Guess this is just one of them things... but hey, i got 2 stripping runs outa it! Guess start buying them bulk!
It's either too heavy or the scale has slipped down. Would like to find one that is calibrated and etched after it's made.
http://www.homebrewit.com/aisle/p/5044" onclick="window.open(this.href);return false;" rel="nofollow -- The Corona Mil. These have been around since dirt. I cut the head off a bolt, threaded it in the shaft where the handle-securing bolt goes, added a jam nut and chucked that puppy into my ancient low speed 1/2" drill. 10 lbs of barley in 20 minutes.
the trick with these critters is to fill them up and then loosen the plate screw. Then while turning slowly with the crank, tighten the screw until the plate starts to bind on the grain. Then chuck up the drill, turn it on. The grain will come out uncrushed or only partly crushed. Tighten the screw until you get the right crush -- I go for just cracking the hull. Then tighten the wingnut on the adjusting screw and grind away. The instructions tell you to set the plates before grinding but it's damn near impossible to get it right when it's not turning. Do it while running and bob's yer uncle. this trick works when using the crank, but takes longer to get it dialed in.
Time's a wasting!!!
