Safe Copper Cleaning Solution.
I need a safe cleaning solution for new copper still. Are there any suggestions?
Bassmanii
- Site Admin
I used the White vinegar solution, and it cleaned wonderfully. Thanks. Bassmanii.CoopsOz wrote:White vinegar, soak all parts overnight. You will be amazed at how effective it is.
Bassmanii
Take one gallon of cheap white vinager and pour in 1/2 cup of salt. Apply to copper and rince off. It cleans fast, but dont leave it on to long it will turn the copper a grey hugh. I pour this into a bucket and submerge my copper scrubbers in it as well. Leave em in for about 1 minute and they are shinny and new. Dont forget to rince though...Pugi
- Site Admin
UJ is right, but for very occasional cleanings it is OK.
Vinegar and salt (or even better than that, lemon juice and salt), simply disolve away the copper (or copper tarnish), and do so pretty quickly. They work "like" an electroplating machine (in reverse), but here are simply ripping the copper off of your material.
However, if you simply rub on, and wash (wash WELL) off, to remove a hard tarnish, then little if any damage is done.
Now for thin structured copper packing, if you treat them like that (dip for a minute to clean), I bet that after 10 cleanings in salt & vinegar/juice, you will have lost much (if not most) of the copper. Scrubbers might have enough material to handle a few cleanings, but structured stuff is pretty fine to start with.
However, even soaking in straight vinegar does disolve the copper also (but to a lesser more controllable extent). I bet commerical copper cleaners would also remove material (but I could be wrong). They "could" remove the O from the copper oxide, and leave the copper, but I doubt that. I bet they are also simply an acid that etches off the surface layer.
H.
H.
Goose Eye, thanks for the hot slop tip. I used it yesterday and I will probably never use vinegar again. The hot slop works faster and seems not to be as savage as vinegar, after all, copper is a precious commodity these days. The ol' timers really did know what they were doing!
Re: yeh
Uncle Jesse wrote:, think statue of liberty
How many stills would that make?
