Proof of your tails
Durhommer
Proof of your tails
Post by Durhommer » Fri Jan 01, 2021 1:51 pm
On a spirit run how far down in abv are you guys running to.
Deplorable
Re: Proof of your tails
Post by Deplorable » Fri Jan 01, 2021 2:02 pm
I run mine down to about 45 to 50%, after that they're pretty funky. Once I start to see oils on the jars or they get cloudy, I usually collect one or two more to see if they clear up, then switch to a stockpot and raise the heat to strip the alcohol for feints collection and collect down to around 15 to 20.
Use all your senses, and its not that hard. You just have to pay attention.
dieselduo
Post by dieselduo » Fri Jan 01, 2021 2:11 pm
I collect to 100 proof and the rest goes in a feints jug
Durhommer
Post by Durhommer » Fri Jan 01, 2021 2:12 pm
Just wanted to make sure I was doing it right I've been collecting my strips in gallons and doing a string of jars on spirits only keeping the middle section of jars with a bit from a front jar and a bit from an end jar
Sometimes I just shut down and dump the pot at a certain abv but that's wasteful of my time and efforts
Master Distiller
Post by NZChris » Fri Jan 01, 2021 2:21 pm
I collect down to about 10-15% at the spout. My combined heads and tails from a flavored spirit averages around 40% and gets aged on oak while I build up enough for a feints run with some added fresh wash.
Master Distiller
Post by NZChris » Fri Jan 01, 2021 2:25 pm
It depends on what you're making too. I'm far less greedy when stripping and spirit running a TPW than when running grains.
Post by Saltbush Bill » Fri Jan 01, 2021 3:17 pm
What sort of still are we talking ? on a reflux still spirit run the abv could still be 94%-93%abv when tails show?
A pot a whole lot lower,,,,,plated column different again.
Durhommer
Post by Durhommer » Fri Jan 01, 2021 3:26 pm
Just simple pot still
Prairiepiss
Master Distiller
Post by Prairiepiss » Sun Jan 03, 2021 8:38 pm
I collect all’s the tails. I mean I Go pretty deep into the tail end. And it all goes in a feints bucket. All the collected that doesn’t make the cut goes in the feints bucket. Heads tails whatever. And when I get enough in the bucket to make a run. It all gets run through for a neutral run. You would be surprised how much good alcohol is actually hiding in them thar tails.
Durhommer
Post by Durhommer » Tue Jan 05, 2021 6:23 pm
I haven't had storage enough till now to really collect feints
goinbroke2
Post by goinbroke2 » Fri Jan 08, 2021 9:15 am
I go down to 20-25% on a spirit run.
