Not sure where to post this:
Almost every time I search I get the message: Sorry but you cannot use search at this time...wait XX seconds and try again.
Usually, after waiting longer than XX seconds, I get the message again. Often I get the message several times.
I assume this is some sort of bot protection but, if so, it is overly protective.
Any solution to this?
Thanks.
Not to get technical, but according to chemistry alcohol is a solution.
Re: Sorry but you cannot use search at this time.
Bot protection yes.
If you can find what you want with the Google HD search it's better than working lists anyways. Solution is 1 part patience, 1 part whisky
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
