3rd use five gallon barrel
My buddy and I have been brewing for years, and he's experimented with wines, meads, and ciders. He's got a 5 gal barrel that had a mead in it for a few years, and then has been evaporating a cider in it for the last like 6 or 7 years. He literally forgot about it in his garage. He sloshed it the other day and says that there's still liquid, but its getting pretty light.
Is this barrel worthwhile to try to use? My thought is to get a new barrel, and make enough all grain bourbon to put in the new barrel, and to make sugarheads w/ the spent grain to fill my buddy's old barrel.
What do you all think? Anything we should do w/ the barrel other than dumping and rinsing? If we find mold or something slimy in the old barrel, is there any way to refresh so that its useable?
I appreciate your input!
K
K
Re: 3rd use five gallon barrel
Mouldy might require more steps but if I were offered a barrel like that I'd probably still use it. The higher abv will be ably to liberate more oak sugars than mead or cider so it's probably still got lots of live left. It if you're very handy a complete refurb would make it like new.
Better there was liquid still in it, not dried out and destroyed.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
- Deplorable
Hard to say what might be in it without pouring it out. Dump the contents, if it was just cider for the last several years, hell, it might have some good vinegar in there. If you get moldy floaters, you're going to have to make the call.
Im of the same mind as Expat, I'd see what it holds. If is smells good and looks good, fill that bugger up and see what it makes.
I'd say mouldy is almost a write off if that's the case. If you still wanted to try, if it was mouldy, I'd get some 'no-rinse' steriliser that we all use for sterilising beer brewing equipment and slosh that around in there for a good while (a day or so) and then thoroughly rinse it out (even though it says no rinse) because it is a sulphite based alkaline solution and I dont know how high strength alcohol would react to that.
- Deplorable
No rinse sterilizer such as Star-San are not recommended for wood.CopperFiend wrote: ↑Sat Mar 06, 2021 1:21 am I'd say mouldy is almost a write off if that's the case. If you still wanted to try, if it was mouldy, I'd get some 'no-rinse' steriliser that we all use for sterilising beer brewing equipment and slosh that around in there for a good while (a day or so) and then thoroughly rinse it out (even though it says no rinse) because it is a sulphite based alkaline solution and I dont know how high strength alcohol would react to that.
- nerdybrewer
If it's not gone bad then I'd use it to age rum.
Personally if I was making an all grain whiskey I'd want nothing but a good oak barrel so that only the flavors of the whiskey and the oak were there.
A rum might profit greatly from all that fruity goodness left in the barrel.
Cranky's spoonfeeding:
Great idea, but I've not made any rum yet! I'm working on bourbon first, as that's what I drink. I figured the sugarhead for the used barrel, and AG for a new barrel that I'll get from a local distillery.nerdybrewer wrote: ↑Sat Mar 06, 2021 9:59 am If it's not gone bad then I'd use it to age rum.
K
The barrel is full. I've got it sitting at 60% bourbon sugarhead.
My buddy did a rinse and overnight soak w/ 2.5 gal of hot water in the barrel and dumped some brown liquid out. I took possession of the barrel and did a bit more of a quick, thorough rinsing to get the brown water running mostly clear, then let it sit over night soaking in a tub w/ a towel wrapped over it to swell the staves. No evidence of leakage for either of us, so I filled it on Saturday night.
It'll sit in my basement or garage until I can get to my place in Northern MI where I'll stick it in the rafters of the pole barn until deer season. After that, who knows! Solera? Empty and refill w/ something else? Who knows. The sky is the limit!
K
K
I put the barrel in the rafters of my in-laws barn on 5/15 full of a 60%abv, bourbon, sugarhead. In the 5 days it was in the barrel from my basement to the rafters it picked up some color and smell. I dropped off my boat at their property on 9/12, and I had my boat cover sitting on top of the barrel. When I removed the cover there was strong odor of cider and honey, and evidence that the spirit expanded and pushed out past the cork while sitting up there. Everthing seemed appropriately sealed and good to go. Sampling and drawing 1 gal out planned for 10/2 when I go to the property for whitetail archery season!! I'll post pics after I sample from the barrel.
I'll likely pick up some corn that weekend and get an AG bourbon going to refill the barrel as a solera before winter is over.
K
K
If the cask is in good shape, I’d start making an all grain or rum right now. Dump that sugar-head into glass as soon as you have enough to fill it.
Hi, kmmuellr,
It would be helpful if you named the month in your dates.
A lot of the world, including me, use a different system, where the date comes before the (numbered) month.
So especially if the number of the month is 12 or less, we could be talking about a completely different date.
Regards,
Regards,
That's fair!! It went into the barrel in May, and I pulled about a gallon and a quarter from the barrel on October 1st.The Baker wrote: ↑Tue Sep 21, 2021 6:19 pm Hi, kmmuellr,
Regards,
Initial tastes at barrel strength (58%) was fairly tart, with a strong apple nose and flavor. I dropped it down to 45%, and similar character remains. Color is amazing.
Overall, I don't know what I expected, but I guess I was hoping for more oak vs. apple, but didn't really know what to expect w/ a barrel that basically had 5 gallons of hard cider evaporate from it!! The spirit is smooth, but rather one dimensional. I'm debating on what to do next.
Last night I blended some w/ two different glass aged spirits (AG bourbon and sour old beer whiskey), and wasn't able to find a balance that I liked. This might make the best Apple Pie ever, but for drinking straight I don't think its up to the challenge.
Options:
1. Refill w/ some more bourbon gumballhead and just keep a solera going.
2. Dump/bottle/glass age and refill w/ AG bourbon
3. Dump/bottle/glass age and refill w/ AG malt whiskey
4. Dump/bottle/glass age and refill w/ rum
5. Dump/bottle/glass age and rebuild/re-char barrel (no clue how feasible that is at the hobby level!)
I'll get pictures posted soon!
K
You need some apple brandy to put in that. If it is pushing that much apple flavor, it should make an incredible brandy. Making me wonder if I could soak some sticks in apple cider, dry them, soak, dry a few iterations and then add them to my brandy.
