Vacuum filtration system
Any hardware used in the mashing /fermenting or aging of product
Re: Vacuum filtration system
Postby contrahead » Wed May 31, 2017 12:17 pm
japsinok wrote: how would you use this kind of filter apparatus?
Chill filtration. Dripping cold hooch through a coffee filter though, won't make it clear. You need a smaller/tighter filter, some form of force and colder temperatures to trap the lipids that cloud some spirits.
In this first video someone is using pressure from a pump to force sub-freezing distillate through a block of filters of some type.
https://youtu.be/OzGypuVGtdQ
In this second video the guy talks about using kieselguhr but shows few details about his filtering apparatus.
https://www.whisky.com/information/know ... skies.html
<or>
https://youtu.be/FTwkT-ohYiY
<extra>
http://www.whiskyforeveryone.com/whisky ... ation.html
https://en.wikipedia.org/wiki/Chill_filtering
contrahead
Postby Bushman » Thu Jun 01, 2017 4:21 am
Sorry I missed this thread when you posted a month ago japsinok. I have often thought of compressing like with a press. It's interesting that my book on making liqueurs on almost every drink that you are soaking flavor to make the drink at the end they tell you not to squeeze the bag after Tincturing as it will carry over the sediments. Having said that to save filtering and filters I think it could be used as a first step or second step (after cooling) in the process.
Postby OtisT » Tue Jun 06, 2017 2:23 pm
Hi folks. I experiment a lot with small batches of product and I am so tired of waiting for gravity filtration through a coffee cone filter. I plan to try vacuume filtration with a vaccume flask and buchner funnel that uses flat paper filters.
What grade of paper do you use?
I am looking for a recommendation on the right grade of filter to use. I'm guessing the answer will vary by product you filter. By grade I mean the largest size of particle the filter will allow to pass, measured in microns or possibly flow speed.
One filter listed as "medium-slow" filters to 7-14 microns and says it is for sugar collection, so this one is too fine a filter for my pantry dropper and other sweet products. I'll need something bigger, for sure.
Thanks for sharing any experience you may have with this. I've only found these filters sold in large numbers of a single grade. I'd love to experiment and try different sizes, but it's just too damn expensive to do that.
Cranky's spoonfeeding:
viewtopic.php?t=52975
OtisT
Postby Bushman » Tue Jun 06, 2017 5:36 pm
Depends on how much I need to filter. If I have large amounts I will first Let it settle in the fridge, then syphon, from here I may screen it. A lot of time I will then pull through paper towels (cheaper) before use coffee filters.
Postby Bagasso » Tue Jun 06, 2017 8:57 pm
OtisT wrote:One filter listed as "medium-slow" filters to 7-14 microns and says it is for sugar collection, so this one is too fine a filter for my pantry dropper and other sweet products. I'll need something bigger, for sure.
I think those filters are for filtering things out of sugars (honey, maple or agave syrups).
Pretty sure you need to get down below 0.005 microns (nanofiltration) to remove sugars.
Some people filter down to 0.5 microns to get rid of chill haze out of their beer.
On the first page of the thread I posted some wash filtered through plain printer paper. A little hazy but a noticeable difference.
Bagasso
Postby OtisT » Wed Jun 07, 2017 10:03 am
Bushman wrote:Depends on how much I need to filter. If I have large amounts I will first Let it settle in the fridge, then syphon, from here I may screen it. A lot of time I will then pull through paper towels (cheaper) before use coffee filters.
Thanks Bushman. Great solution but it's moving the wrong way for me, speed wise. I'm mainly interested in Quart at a time filtration. If I ever need to do a large batch, I may try your method.
OtisT
Postby Bushman » Wed Jun 07, 2017 3:58 pm
Sorry if I wasn't clear but I was not talking about large batches but a lot of sediments that would plug a filter fast. An example would be Tincturing strawberries or something that leaves a lot of particles.
Postby OtisT » Wed Jun 07, 2017 4:20 pm
Bushman wrote:Sorry if I wasn't clear but I was not talking about large batches but a lot of sediments that would plug a filter fast. An example would be Tincturing strawberries or something that leaves a lot of particles.
Thanks. I see what you were getting at now.
And turns out your post helped me even though I miss understood it. Your paper towel comment gave me an idea. For my new Büchner filter, I simply cut 110mm circles out of large coffee filters and Bam!, I've got a 10 cent filter for a penny.
It all works out in the end. :-)
OtisT
Postby OtisT » Sun Jun 11, 2017 2:58 pm
just a follow up to my adventures in vacuum filteration. I had my first need for using my new Boucher filter on a vacuum flask. Rather than buying lab filters at 10 cents a pop, I cut two 110 mm circles out of one #4 coffe cone filter for a penny each. They work fine.
I had 800 ml of backset I wanted to filter, which with my old coffee cone gravity filter would have taken many hours and many filters to accomplish. With the new rig, I was done with filtering and cleanup in 15 minutes. It took two filters to filter this once, and I refiltered the entire amount with a third filter for good measure. I'm using a Food Saver for the vacuum source.
I am going to love this rig each time I use it. :-)
Vacuum flask with Boucher filter
OtisT
Previous
Return to Mashing and Fermenting Flavoring/Aging Related Hardware
Who is online
