ultrasonic aging experiment
DBCFlash
Post by DBCFlash »
I recently built a 100 watt ultrasonic aging device (UAD) to determine if ultrasonic aging of spirits is a real thing or just a gimmick. I've been asked by a number of respected members of this board (and a couple of scoundrels) to document these experiments and post my results. I'm normally a much more "seat of my pants" kind'a guy, but for the sake of this procedure I'll be writing everything down and presenting it here...You're welcome.
This is the UAD I built. It's simply two half gallon Bain Marie pots, one cut, flipped and nested to allow room for the transducer. I haven't even put the control board in a box yet.
The parameters I've been asked to measure are:
Starting weight- 4 pounds 10 1/2 oz
Starting temperature - 65 Degrees F
Measured volume - Just a hair under the 500 ml line
ABV - 99 Proof
I am running the UAD for a 40 minute session. I'll post the results and my subjective evaluation of the resulting changes in flavor and texture.
Some men you jest cain't reach...
This topic has 52 more replies
Register Login
