Barrel aging in a Patio Table
Crazy idea I had, and I don't know if its been done or is ridiculous.
My thought was to build a patio table out of an freshly emptied bourbon barrel (full sized). Basically a vertical barrel w/ a glass top and stick it on my back porch which gets full sun from the first thing in the morning until around 6pm in the summer. Much less sun during the winter, since I'm in southeast Michigan. Major temperature fluctuations (-10F to 100F, winter to summer; daily extremes up to 30 degrees sometimes.)
Plan would be to go crazy making bourbon and fill the barrel, and then just let it sit outside on the patio. Pull a bottle or two out periodically when I make a new batch and re-fill w/ fresh white. Kind of a solera batch of whiskey, aged in the outdoors of Michigan. At this point lets discount how difficult generating this much whiskey would be, I'm sure I can get a buddy to help.
Good idea, bad idea? Really stupid, bad idea?
Assuming a full barrel, would it leak over time if I kept it full? The only protection from the elements would be a glass top, would it dry out the staves to much?
What could possibly go wrong?!?
K
K
Re: Barrel aging in a Patio Table
A “freshly emptied bourbon barrel” is a biiiiiggg vessel. That would be a lot of bourbon to make...and ultimately, to drink. Cheers.
And they’re heavy too. Make sure you put it where you want it to stay. Moving a full cask is a PiTA.
Well, I’ll give you credit. it’s ambitious. However here are some logistical thoughts.
You probably need to fill it at one shot. Otherwise the staves will dry out above fluid level and it will leak. So that means storing a shite ton of carboys—somewhere else. If life or SWMBO gets the honey-do list too long there could be a serious delay. Depending on current fermentation sizes, that is a fair amount of end-to-end batches. So I’ll just say you should be fully committed to a several month project. Family has a way of cheering you on until they all realize you’re busy—all the time. Don’t count on ongoing help. They disappear into thin air after the novelty wears off. And to top the list, the Angels Share will probably be very large. Out in the sun on the deck it’s gonna get hot.
Would I attempt it—probably not. But I’m not you.
Would I use one for a table—absolutely. Cool idea.
Have fun with it
J
Have fun with it
J
If in doubt leave it out.
Totally fair comments, and I agree 100%! I've worked w/ home brew clubs and filled recently emptied barrels w/ beer. Way easier than filling by myself w/ whiskey!Jstroke wrote: ↑Tue Jan 05, 2021 11:06 am Well, I’ll give you credit. it’s ambitious. However here are some logistical thoughts.
Have fun with it
J
Maybe I'll do a 10 or 15 gal barrel and stick it inside a full barrel on the porch. Might be a more easily completed project!
K
It’s all I can do when working on filling my 5G cask. Works out to over a dozen ferments & runs. I’m retired and it still takes me 6 months to a year at best. But I’m more than okay with this situation. My 5G pot & cask keep me well within hobby limits and provide plenty of sipping material in the process. Good luck!
- Twisted Brick
+1
I do 13gal mashes, and I just completed my 9th and final strip run on my way to filling a five gallon barrel. This job has been six months what with COVID, still-building and life.
What could go wrong is you mortgage your soul to fill any larger size barrel and you're not crazy about the final product.
Just sayin'.
That would be a really cool table though.
- Deplorable
Not an endeavor that I would undertake.
But what I would do is fill a 5 gallon and put it at the end of an outdoor bar on a covered deck.
I worked nonstop, for 8 to 10 weeks with a 32 gallon brute and a 13 gallon still to fill a 5 gallon cask with single malt.
I'm not going to attempt another 5 gallon barrel filling until I see how this one turns out. (Famous last words)
But don't let me stand in the way of your ambitions. Best of luck, and may you live long enough to get it filled, aged, and consumed.
I dont think there is a hobbyist on this site that has filled more than a 15 gallon cask. (I'm sure the pros with a DSP# on here have.)
Ive just finished filling a 25 us gal barrel, its a lot of distilling and is as big as I will ever fill.
No matter what you decide keep it away from prying eyes and under lock and key.
- Deplorable
Damn.Saltbush Bill wrote: ↑Tue Jan 05, 2021 7:55 pm Ive just finished filling a 25 us gal barrel, its a lot of distilling and is as big as I will ever fill.
Impressive stash!
Thanks for everyone's input!!
K
K
I personally wouldn’t sit it in direct sunlight. Heat is ok. Temp swings are needed. But direct sun would be way to much heat. I bet the angels would love you for it though.
It would also be hard to keep the staves that are on top from drying out and separating and or leaking. It would need to be turned regularly.
Put it in a shed or a barn and forget about it.
