I decided to upgrade my fermenter
sorry i have given up on figuring out how or why my pics are always rotated
got these strainers from US Plastics, they snap/thread over the 3/4npt nipples i threaded in the bulkheads
here they are installed
here is the barrel with the valves
normally i open ferment but figured I'd add a blow off tube so i could be under airlock
Along with all this i got some EZ Strainers for 5 gal buckets from US plastics too. Figured if i am gonna dedicate myself to all grain i should have some tools to make the job easier
fermenter upgrades
fermenter upgrades
Don't let your meat loaf.
Re: fermenter upgrades
I like the square barrel look. Is it #2 plastic stamped?
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
- Deplorable
I'm interested in how well those work out for you. I am subscribed for the update.
- Stonecutter
Do you plan to ferment on the grain? I ferment off the grain, BRIAB style and noticed that if I don’t vorlauf properly the strainers I use to rack with get gummed up pretty damn quick. I’m also a straight up newbie so I contribute 99.9% of the difficulties I have to that fact. Very interested to see your results
-Thomas Paine
-Thomas Paine
yea hdpe #2 I've fermented in them for years. 65 gallon. I ferment on the grain, my goal with the strainers is I will steep/soak the grain before i cook it in the barrel. The strainers are so i can draw the water that's sour off the uncooked grain and use it in the boiler to cook the grain with. I'm hoping it works good. Never know until i try.
Wouldn't mind having a couple like that. LoL More capacity in roughly the same space.ezlle71 wrote: ↑Tue Apr 20, 2021 5:17 amyea hdpe #2 I've fermented in them for years. 65 gallon. I ferment on the grain, my goal with the strainers is I will steep/soak the grain before i cook it in the barrel. The strainers are so i can draw the water that's sour off the uncooked grain and use it in the boiler to cook the grain with. I'm hoping it works good. Never know until i try.
What do you want to accomplish by soaking the grains, what is making the water sour? If you're grinding the grain before soaking I'd guess you're going to have a challenging time getting the water back out.
You're using steam to cook it in the barrel?
EXPAT
___________________
EXPAT
___________________
I found out the barrels were used for sausage casings, Smithfield has a plant here local. They are usually easy to find around here for 25-30$ a piece
Soak the grain like a sour corn starter. Let it go thru the 3 bacterial ferments and soften up for easier cooking and gelatinization.
I'm not looking to get all the water back outta the soured corn. I would rather it soak water up at this stage then during the mashing process
https://homedistiller.org/forum/viewtop ... =3&t=65703
using Shineoncrazydiamond's large batch mashing model and high temp alpha amylase enzyme. Planning on 40 gallon batches with 80 lbs of corn
