Thinning the mash with water AFTER Ferm to get more wash out??
- EricTheRed
I read somewhere on this forum about this, but cannot find it now
once fermentation is done, let settle, take off all the thin/clear liquid
then add xx% water back into the now thick mash to have the alcohol and water bond
let settle, take off the thin/clear liquid
squeeze the rest
Is that a thing or did i completely get that wrong?
squeeze the rest
Life has gotten interesting!
- EricTheRed
Re: Thinning the mash with water to get more yield??
almost - but not the post i was thinking ofMetalking00 wrote: ↑Thu May 26, 2022 12:37 am I think youre thinking of this one
viewtopic.php?t=86985
maybe it was Setsumi - let me hunt around his posts
No, it was not me. I have a dutch cheese press to press the meal.EricTheRed wrote: ↑Thu May 26, 2022 12:51 amalmost - but not the post i was thinking ofMetalking00 wrote: ↑Thu May 26, 2022 12:37 am I think youre thinking of this one
My first flute
My press
My twins
My controller
My press
My twins
My controller
- EricTheRed
Like your press btw! - did you ever upgrade those milk crates?Setsumi wrote: ↑Thu May 26, 2022 2:33 amNo, it was not me. I have a dutch cheese press to press the meal.EricTheRed wrote: ↑Thu May 26, 2022 12:51 amalmost - but not the post i was thinking ofMetalking00 wrote: ↑Thu May 26, 2022 12:37 am I think youre thinking of this one
I use this one - which works pretty well if you let it gravity drain for a bit first The post i am referring to was something about adding water to the thick mash after fermentation and taking off the clear liquid to help get the alcohol molecules away from the thick mash.
So anyone have thoughts on the feasibility of such a thing?
Re: Thinning the mash with water AFTER Ferm to get more wash out??
Seems like youd get a bit more alcohol at the cost of watering down your flavor, similar to the idea of bumping up your abv with sugar to just get a bit more per run. You would also be lowering your boiler abv.
I had also thought of rinsing the grain after squeezing (like was mentioned in the thread i linked) and keeping the second washing for its own run to see how much it actually got out of the grain, and what kind of flavor it has left. But, Im lazy and i dont think theres gonna be enough left to make it worth it.
- EricTheRed
But would it really dilute flavour? I'm not adding anything else - it would be a bit like watering down your lowwines - not seen anyone saying that dilutes flavour? Remember, it is AFTER fermentation - not after enzyme actionMetalking00 wrote: ↑Thu May 26, 2022 4:18 am Seems like youd get a bit more alcohol at the cost of watering down your flavor, similar to the idea of bumping up your abv with sugar to just get a bit more per run. Maybe try it and keep the second washing for its own run to see how much it actually got out of the grain, and what kind of flavor it has left.
I edited a bit while you were posting.
Ive seen it recommended to strip until you are at a low enough abv to reach a target abv in your spirit run so that you dont have to dilute your low wines which could dilute your flavor. Diluting low wines more than usual is done when making neutral specifically for that reason.
What the difference would actually be, I dont know. Im still quite new to all this...
Yes I use my ss mushtun now. Nice press yourself.EricTheRed wrote: ↑Thu May 26, 2022 2:56 amLike your press btw! - did you ever upgrade those milk crates?Setsumi wrote: ↑Thu May 26, 2022 2:33 amNo, it was not me. I have a dutch cheese press to press the meal.EricTheRed wrote: ↑Thu May 26, 2022 12:51 amalmost - but not the post i was thinking ofMetalking00 wrote: ↑Thu May 26, 2022 12:37 am I think youre thinking of this one
While you can press, why dont you just "sparge" your pressed grains with a small amount of water? That way you will not dilute your boiler charge much.
My first flute
My press
My twins
My controller
My press
My twins
My controller
- EricTheRed
Methinks I'll try this on my next mash currently on the goSetsumi wrote: ↑Thu May 26, 2022 7:46 amYes I use my ss mushtun now. Nice press yourself.EricTheRed wrote: ↑Thu May 26, 2022 2:56 amLike your press btw! - did you ever upgrade those milk crates?Setsumi wrote: ↑Thu May 26, 2022 2:33 amNo, it was not me. I have a dutch cheese press to press the meal.EricTheRed wrote: ↑Thu May 26, 2022 12:51 am
- jonnys_spirit
I’ve done this a few times. Siphon beer to the grain bed then add water - maybe enough for another strip or half strip(?), let it all settle and siphon again and run it. Might be easier than squeezing. This worked fine and of course did produce less low wines on that strip. Lately I’ve incorporated my second ferment rat bastard rumski-head on spent AG grains to put off all the bending over and squeezing and still use the beer left in the bottom of the ag barrel.
-j
-j
- Deplorable
Bending over?jonnys_spirit wrote: ↑Fri May 27, 2022 4:27 am I’ve done this a few times. Siphon beer to the grain bed then add water - maybe enough for another strip or half strip(?), let it all settle and siphon again and run it. Might be easier than squeezing. This worked fine and of course did produce less low wines on that strip. Lately I’ve incorporated my second ferment rat bastard rumski-head on spent AG grains to put off all the bending over and squeezing and still use the beer left in the bottom of the ag barrel.
-j
For what? I put my mop bucket on top of a 5 gallon bucket, and it puts it at just the right level that I don get fatigued.
- jonnys_spirit
I do that too but there’s only one good way to scoop the slop out of a 50g hdpe barrel and that involves practically climbing into it to get maybe three or four scoops into the mop strainer set into the 5g bucket. An hour or so of that effort and my back hurts. If I can make it 1/3 or half the effort then I’ll go with it.Deplorable wrote: ↑Fri May 27, 2022 7:25 pmBending over?jonnys_spirit wrote: ↑Fri May 27, 2022 4:27 am I’ve done this a few times. Siphon beer to the grain bed then add water - maybe enough for another strip or half strip(?), let it all settle and siphon again and run it. Might be easier than squeezing. This worked fine and of course did produce less low wines on that strip. Lately I’ve incorporated my second ferment rat bastard rumski-head on spent AG grains to put off all the bending over and squeezing and still use the beer left in the bottom of the ag barrel.
-j
Bad back for many years so I’m just a little triggered and sensitive and want my whiskey trophy now please…
-j
- Deplorable
Ahh. Tall barrels.
That's been one of the reasons for me sticking with 30 gallon barrels. I can reach the bottom with a 2 quart scoop, and what I can't scoop, gets lifted and poured.
The downside is it takes more ferments to get a 5 gallon barrel full of spirits.
