Using a PID that does that on elements that were not designed for it has killed two elements for me before the jobs were done. Both times, I knew it was a possibility, but thought I would get away with it
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
you got a wiring diagram for this beauty? When my boys are out of school this summer and I can't run, I plan to upgrade my controller box. Right now I just have a still dragon design. no on off switch, no fan. I'd also like to make a ccvm column so I'll need some temperature monitoring and more precise control than the dial knob.Salt Must Flow wrote: ↑Fri Jun 03, 2022 5:17 pm bcook608 are you still in the planning stage or did you already buy a bunch of stuff?
The reason I asked is because you can use a different enclosure and have a forward facing controller rather than a top facing controller. Here's a project box I used for my most recent 240V build using the Auber DSPR 400.
I mounted a fan on the top which blows air down directly over the SSR and the air vents out the side. Here's some pics I just took.
Front view. There's a green power indicator light, the DSPR 400, an alarm/light/buzzer and an alarm kill switch.
The rear has the power in, the power out, a RTD sensor connector and the power on/off switch.
Side view with a fan guard where the air exits.
The underside has 4 rubber feet.
I tried sending you the wiring diagram in a private message, but it wouldn't allow me to attach an image for some reason so I posted a topic with the controller build.psf wrote: ↑Sat Jun 04, 2022 5:18 amyou got a wiring diagram for this beauty? When my boys are out of school this summer and I can't run, I plan to upgrade my controller box. Right now I just have a still dragon design. no on off switch, no fan. I'd also like to make a ccvm column so I'll need some temperature monitoring and more precise control than the dial knob.Salt Must Flow wrote: ↑Fri Jun 03, 2022 5:17 pm bcook608 are you still in the planning stage or did you already buy a bunch of stuff?
My only issue is that I'll have to run separate 110V into the box because my garage plug is a 3 wire welding plug.
Thank you sir! I will probably have follow on questions in that post when I get to it but for now I have it bookmarked and its enough to let this old dog hunt. Thanks againSalt Must Flow wrote: ↑Sat Jun 04, 2022 9:19 am
Auber EZboil DSPR 400 Controller
Yes, it is. It's a trick I use with elements that are heating washes. I got frustrated with waking up on frosty mornings to find a fermenter freezing the nuts off my yeast because of a blown element, now all those elements are used with two in series so that they only put out 1/4 of their rated Watts. I haven't had a blown element since.
That sounds like JUST what I'm looking for. All that other extra stuff is just confusing to me. Maybe after I get the hang of electric I'll branch out to the other fancier units.Salt Must Flow wrote: ↑Fri Jun 03, 2022 5:23 am If all you want is a variable power controller, no temp reading and zero bells & whistles then the DSPR1 will be just fine.
Something like this would work nicely if you are mounting this box vertically. Both power cables could be installed through the bottom like you mentioned.
Damn, that does look better. Then I could put the vent holes at the top and convection and the fans will push the warm air out the top and pull the cooler air in the bottom.Salt Must Flow wrote: ↑Sun Jun 05, 2022 3:06 pmSomething like this would work nicely if you are mounting this box vertically. Both power cables could be installed through the bottom like you mentioned.
You'll love using your controller once it's finished. If you ever do choose to use another EZboil model, your current components can be used rather than building an entirely new controller with all new parts. That amp/volt meter is going to flicker like crazy when running at any % power other than 100%, but will work perfectly with that Still Dragon kit with SSVR & potentiometer.bcook608 wrote: ↑Sun Jun 05, 2022 2:29 pmThat sounds like JUST what I'm looking for. All that other extra stuff is just confusing to me. Maybe after I get the hang of electric I'll branch out to the other fancier units.Salt Must Flow wrote: ↑Fri Jun 03, 2022 5:23 am If all you want is a variable power controller, no temp reading and zero bells & whistles then the DSPR1 will be just fine.
They're clear, they won't have any internal baffling in the vapor path, and the end is more cone shaped than bowl shaped. I was limited by the shitty program on my computer. It's also a modular build so I'll be able to adjust the angle and will likely run it at a more severe angle to promote flow.EricTheRed wrote: ↑Sun Jun 05, 2022 10:23 pm Just make sure that your shotgun doesn't have restrictions when running at an angle. Ie. Tubes are free of any liquid.
That's why I went with 90s, figured I'd probably have to have the shotgun at a more severe angle. Plus it'll let me rest the condenser against the pot for bracing itselfSalt Must Flow wrote: ↑Mon Jun 06, 2022 6:55 am I'm all for using multiple 90 elbows, but you could save a few bucks by using a 2" stainless U especially if you consider the additional gasket & clamp that would be needed using elbows. One benefit to using elbows is that every joint articulates so you can set the condenser at different angles easier. You'll be good to go either way you do it.
Right now I have (5) 1" holes in the top. No cover at the moment but I will be adding some screen to the inside of the box to make it look nicer.Salt Must Flow wrote: ↑Wed Jun 08, 2022 5:52 pm Well that turned out very nice! My wiring typically looks like spaghetti too. I tend to focus more on whether it is wired right than how the wiring looks too.
Would you mind posting a pic of where the air exits? Do you have fan guards covering the exit holes?
Thanks Chris!
I have to wait for payday to get the element and ferrules to braze on for the conversion but once I'm back up and running I'll do some experimentation and let you know how the different modes affect the controller and the behavior of the element/still.
Those are perfect!Salt Must Flow wrote: ↑Sat Jun 11, 2022 9:41 am I 3D printed several of these vent covers for the 1" vent holes in your enclosure. They're resized from this model. You should be able to glue them in place. I've reinforced similar things by applying hot glue around them on the interior of the enclosure.
