Bushman wrote:Sounds like you have personally used it. I have the MMII which I like. Can you give the members a bit more information about the product? How sturdy is the plastic, does the grain clog or go through with little effort, how hard is it to adjust to different size mill, etc.?
Yes I have it and have now run about 100lb through it.
The plastic bin is very sturdy. The upper part is all metal. So as you can imagine it's sturdy as well. The grain for me does not clog. I'm grinding TSC cracked corn with the smallest sieve plate and chews right through it.
The plates are easy to change. Just to nuts on the bottom to change them. The only thing I had to do was slightly dimple the smallest plate where the blade bearing is as it was a bit too close to the plate and was "burning" the plate.
The hopper easily holds 23lb of grain. I just load it up and stay working on other things. Oh for the noise level it's about as loud as a large shop vac so not uncomfortable.
The mill was designed for farm use grinding grain. With that in mind the store I linked to also sells all the replacement parts which is nice as we all know it's not if but when something breaks.
Hope that helps. Let me know if you have any other questions.
Sent from my Nexus 6P using Tapatalk
