Hi,
I'm looking into buying a distilling controller. I need something that provides 22KW of power (4x5500W elements).
I found this one, but it only has 1 SSR and only supports 7KW.
https://www.auberins.com/index.php?main ... cts_id=690" onclick="window.open(this.href);return false;" rel="nofollow
The DSPR400 supports up to 6 SSR in parallel, so I guess I can use this as a starting point. Any guidance will be appreciated.
Thanks,
22KW control panel build
Re: 22KW control panel build
What is your application for, as 22kw is more that a hobbyist requires, so many will not respond to your question.. and a PID controller is not the best for distillation..
Mars
Mars
– Albert Einstein
– Albert Einstein
Unless you actually need to precisely control more than 5500 watts, I might just control one element with a controller and the others with on/off switches.Birzzz wrote:Hi,
Thanks,
Of course this only works if 5500 watts is sufficient to operate your still after warm up.
Can you tell us more about your setup?
Man, if'n I heated my keg still with 22Kw...
B up to temp in less than 5 minutes...lmao...
Sent from my SM-G950U1 using Tapatalk
Plus you want your 22kW to be 80% maximum of total power available, so you're looking at a 28kW controller MINIMUM.
Always over rate your controller --don't match it.
Plus of course 22 kw is nearly 100 Amps even at 240 volts ! Need a decent sized wire and plugs etc -
Hi,
it is indeed not destined to be for home usage. I'm just testing the waters, it's for a future project. The unit would control a 100 gallon stripping bain-marie still. You said PID are not good for distillation, can you elaborate?
Thanks,
Thanks,
Distillations are controlled by power input which in turn controls product output. Running by temperature is a futile effort, and PIDs control temperature only.Birzzz wrote:You said PID are not good for distillation, can you elaborate?
There is no Magic Temperature as it's a moving target. It would be great if we could set our stills for X°, but we just can't and expect success.
As the mixture boils and thus the components change and vaporize, so does the combo boiling point.
So continue looking for a power controller.
- rubelstrudel
You really do not need one single power controller for all elements.
You get yourself 4x 6kVA voltage regulators, or power regulators.
Each regulator controlling 1 element would give better en finer control over the heating than a single controller.
Thats what you want. Control over the power input in your system. Not trying to have the system maintain a specific temperature.
The whole point of a fractioning column is to maintain that temperature for you using the power equilibrium between energy input and energy removal.
Using a PID controller for heating will only result in oscillations in temperature removing any hope of a clean distillate.
Assuming that you are using 230v/5.5kw elements- thats a whopping 25A/230V fuse for each of these heaters.
I wouldn't run this on anything less than a 3x 4mm2 copper cable. If you're talking 110V that goes up again.
But you're probably talking about 3x400V 3-phase power supply here? Right?
Easier to run 3 or 6 heaters then, to get an even load.
But now we're into heavy duty electrician territory.
Always impatient. But learning.
