Is a pH controller like this one used to dose in saturated limewater:
https://www.bulkreefsupply.com/milwauke ... oller.html" onclick="window.open(this.href);return false;" rel="nofollow
overkill on sugar washes which tend to crash?
I've use them on an aquarium, but maybe it works as well (and is certainly cheaper) to dump in some chalk at the start or a a handful of oyster shells and not think too much.
pH controller
- bluefish_dist
Re: pH controller
For most ferments, a daily check is plenty. If you need more buffering, try adding both citric acid and calcium carbonate at the beginning. It allows you to increase the dissolved cc and still have the right ph.
I also like a ph lower than 5, so the controller in the link would not work.
Formerly
Dsp-CO-20051
Dsp-CO-20051
Re: pH controller
Right, you'd need the MC110 model to control in a range of 3.5 to 7.5.bluefish_dist wrote:For most ferments, a daily check is plenty. If you need more buffering, try adding both citric acid and calcium carbonate at the beginning. It allows you to increase the dissolved cc and still have the right ph.
Edit: which doesn't actually have control, just a monitor, so that wouldn't work anyway.
