I have, over the past few years, worked on building a control board. I wanted it to be able to brew beer and distill. I got the board done, but the coding for it is proving to be difficult. I intend on the code being open source, but would like to get it basically working first before I link it out to the masses. Is there someone here that wouldn't mind assisting me? Basically I need help getting the architecture of the program in place, I can code the rest of it. All my friends are c# developers (as am I) and don't think about memory usage and cycles lol.
what's in it for you? I would prefer giving you a board, but if other compensation is requested, we can have that discussion.
Looking for some help from a Senior C++ developer
- amdamgraham
Re: Looking for some help from a Senior C++ developer
You mention being a C+ developer but there may be more Python folks out there who could write something - then you just need to brush up on python for editing? Just a thought.
I am pretty fluent in python, but due to the integration and low level controls, c++is my best bet.
- jimmayhugh
What microprocessor are you using?
I've done projects using the Teensy Microprocessors, and one of my older projects was featured on Hackaday in 2014.
It is based on an ESP32-WROOM-32U
Funny enough, I have 3 one-wire busses on here for temp sensors. I was taking an arduino-coding approach to this using the arduino-esp32 library but the project has outgrown the capabilities of the Arduino IDE and im now using VS Code with PlatformIO
- jimmayhugh
I've also worked with the ESP8266 and ESP32. I currently have an ESP32 monitoring 8 DS18B20s on separate 1-wire busses and providing output to 8 I2C display devices while simultaneously sending data to a webpage via UDP for inclusion in a database. I'm not even close to outgrowing the capabilities of the Arduino IDE.theskaz wrote: ↑Thu Dec 19, 2019 11:59 am It is based on an ESP32-WROOM-32U
In my recent projects, I've returned to the Teensy devices simply because the Teensys
have more I/O, are faster, cost-effective, and less troublesome. I still use the ESP8266 or ESP32 for their WiFi capabilities, under the control of the Teensy.
I use the Arduino IDE simply because many noobs can then use the code with a minimum of problems.
Have you started a GitHub repository? I'm a full stack developer in my day job but it's been years since I wrote anything in C++. These days I write more C#. If you've got a repository maybe I can look at what you have and help you figure it out.
Sorry, holidays got in the way.
here is my Github:
https://github.com/hicotton02/BeverageController
it might be hard to read because I am in the middle of just trying to figure out what to do. Here is a list of requirements that I set, and would like to implement:
here is my Github:
- All factors of the Brew Controller/Still (BDC for short) can be controlled through the display or IoT(Alexa for example)
- If an IoT command comes in, it notifies the display, and vice versa
- The display is a Nextion 7" or 10" display
- It will display current IP Address, SSID, and Amperage across the top of any page
- any errors should be displayed on the current page
- any and all safety measures should kill the system. An example is if you are using a recirculating pump and the temp goes above 200. (means you arent knocking down vapors anymore
- A user can pick auto or manual
- auto means that it will run boiler up to X temp @ 100% power, and once foreshots start, pull it back to Y% power, and maybe some other things. not meant to be a set it and forget it thing, just somewhat intelligent
- manual means you can turn on the boiler, and recirculating pump manually, set the power % manually, and monitor temps on screen
- a user can pick auto or manual
- right now, manual is all I care about
- A user can set through IoT or display, the target temp for the Hlt, Mlt, and boiler.
- once temps are set, and user turns on element with a button (or IoT input) a PID kicks off controlling the rise to temp.
- There is a timer on the screen where a user can set the time, and have it count down until 0. (for example if your final boil should be for 90 minutes, you can track that)
