Controller goodies
Controller goodies
What goodies do you use in your controller that are reliable. Links are king here. If it is reliable post it. Switches, lights, amp meters, voltage meters, 110 to 12v. Buttons and do gathers Long life items are king here. Goodies only please. Thanks.
- cranky
Re: Controller goodies
Great idea Halfbaked,
Since I have my spare parts sitting right here I will list them.
My SSR is a Fotek SSR-40VA and it came from Amazon with the heat sink
That listing shows currently unavailable but there are a couple others still selling it
I don't know the brand my digital volt/amp meter is but it has a label that identifies it as model DL85-2041. There are several Amazon links available if you search that number. Here is one
I have the voltage side wired to read voltage at the switch before the SSR because I read if you wired it after the SSR you will burn it out. Originally I had it wired after the SSR and ran it numerous times like that with no failure but rewired it as a precaution.
My switch is a Leviton 30 amp double pole single throw switch from Home Depot P/N 3032
https://www.homedepot.com/p/Leviton-30- ... /100356941
I've been running the SSR since July of 2014 and have even accidentally run it a couple times without the fan and had no issues. The meter and switch were added in March 2015 and there has never been an issue with them.
That’s a great start. Lots more to go
My DL85-2041 meter didn't last long at all. It didn't fail during a run, but it has started spewing nonsense numbers and no amount of blowing out dust and using CRC 2.26 spray has resurrected it yet.
https://images-na.ssl-images-amazon.com ... 7Qr1yL.jpg
MEAN WELL RS-15-12 AC to DC Power Supply Single Output, 12V 1.3 Amp 15.6W
5.0 out of 5 stars 5 ratings
Price: $11.51 FREE Shipping on orders over $25.00 shipped by Amazon or get Fast, Free Shipping with Amazon Prime
New (2) from $11.51 & FREE Shipping on orders over $25.00
Specifications for this item
Brand Name MEAN WELL
Ean 4021087014786 , 7991166456813 , 8068020056621 , 0723175130012
Input Voltage 12.0 volts
Is Assembly Required false
Item Weight 0.705 ounces
Manufacturer Series Number RS-15
Model Number 1919051
Number of Items 1
Part Number RS-15-12
Specific Uses For Product personal
UNSPSC Code 43211600
UPC 723175130012
Voltage 12 volts
Wattage 15 watts
This is great for adding 12 volts items such as fans lights etc. not the cheapest available but easy to use. No soldering required.
Number of Items 1
UPC 723175130012
Voltage 12 volts
Wattage 15 watts
Not sure if really allowed to post link but all the products I have used from here have been great. They also have great service.
www.auberins.com
I am not connected to them in any way. Just a customer.
www.auberins.com
I'm going to give a hard second on anything from www.auberins.com. Great products and great customer service. Everything I use came from them.
They sell kits and accessories all the way up to assembled units.
