SD 240V Controller Pot: 50%=0, too sensitive
Re: SD 240V Controller Pot: 50%=0, too sensitive
Good point Larry , don’t even get me started on the controllability of my High pressure gas reg
Hi,
Necro post on the starting at 40% before anything happens.
I noted that many controllers on sales start at 80V only. So the range is 80 to 220V. 80/220 = 36% (circa the 40% alluded to).
Took me a while to find one that started at 0 to 220V.
Here you go, sorry for the delay
Loosen the screws and slip the resister leads in with the wires going to the pot.
Try a 470k resister rated at 1watt or more.
