Still Dragon DIY Controller build- 220
- Tom Kat
I went with the larger box. Step one is to ventilate the box. I started with a pilot hole and used a step bit to make my air holes.
theThere's no place like home
- Deplorable
Re: Still Dragon DIY Controller build- 220
This thread is relavent to my intrest. Please proceed.
I''m planning on building one of these next month, with the possibility of a couple of additions.
This was my "build." I bought a large generic electrical "J" Box from Lowes "big box store," and I also installed a computer "pancake" fan for drawing in cooling air, and a grilled vent for hot air discharge.
- Tom Kat
That looks nice, I like the fan idea.
Did they include the screws to mount the parts in your kit?
Screws for mounting heat sink, SSR, feet are included.
I like the use of a breaker in the control box for a on off switch. I bought a SSVR Kit years ago and the on off switch gave up on me. so i had to just direct connect it. This is a good idea for that solution. thank you
Don't let your meat loaf.
My comment is with respect to your heat sink.
To locate your heat sink inside your box as far as I am concerned is wrong and ought be positioned on the exterior. This is easily accomplished with a few cut outs for a SS plate and subsequent mounting. This way, your heat is kept external doing away with fan requirements.
For my 60L stills I do this as a standard and no internal excessive temperature is encountered even when running at 5.5KW
- Tom Kat
It's important to have your element covered with liquid BTW.
You didn't
I discovered that in my water heater the other night. [emoji2957]Tom Kat wrote:It's important to have your element covered with liquid BTW.
- Deplorable
Damn. That cost ya more than my fuck up. Education is expensive isn't it?
- Tom Kat
Yeah that was a $90 fuck up, born of ignorance and excitement.
Oh well, wont be the last time I am sure.
The worst part is being on the 99 yard line and fumbling. My son did a great job wiring up the controller, installing a 30 amp breaker, and running the 10/23 Romex.
So now I get to clean mason jars, read about distilling, and wait for my new element. Hopefully my DADY and nutriant etc will get here soon and I can start some birdwatchers.
- Deplorable
I smoked 2 pots and a SSVR, and had to run 28 gallons on propane. 3 stripping runs yesterday and a spirit run today.
New parts will be here well before I need them again. I'm pretty well stocked up right now.
