Banjo burning with a yellow flame
LP, NG, gas burners of all types. Wood, coal or Steam equipment.
scarecrow
Post by scarecrow »
My 3 ring burner is playing up, I think.
When I first got it, all rings made a nice blue flame when flat out. Then the inside ring started to be more yellow than blue. Now all three rings have more yellow flame than blue.
What's the problem here? Is it blocked or rusted inside?
There is a lot of grey coloured powder all over it.
Would a re-bore help? Is a port and polish going too far? :lol:
scarecrow
Tater
Re: Banjo burning with a yellow flame
Post by Tater »
Check to see if spider webs aint blocking it.And air shutters if has them are open .
Smokehouse Shiner
Post by Smokehouse Shiner »
I bore out the flame ports on my burners pretty regular. They rust and close up slowly over time. Just take a proper sized drill bit and drill em out then shake blow or otherwise get rid of the rusty dust you've made. Good as new.
This is grain, which any fool can eat, but for which God intended a more divine means of consumption...
Prairiepiss
Post by Prairiepiss »
This mite seam to be a silly question but got to ask. Are you using it indoors or out? Is there proper ventilation? I know its not a good idea to run one indoors. But being secretive with our hoby has some running them in a confined space. Yellow flame happens when not enough oxygen is mixed with the fuel before combustion.
We lived in this 100 year old house that had the little propane wall heaters in every room. I replaced a few of the ones we used the most. With the vent free blue flame ones. They have a sensor setup that shuts them off when the oxygen levels get to low. I had one room that the heater would shut down all the time. I finally installed a vent to another room in the wall and one in the door. Never happened again.
scarecrow
Post by scarecrow »
Prairiepiss wrote:This mite seam to be a silly question but got to ask. Are you using it indoors or out? Is there proper ventilation? I know its not a good idea to run one indoors.
I do run it in the garage, but the door is always open about a foot, and the burner is right next to the opening.
I might do a bit of maintenance on it this week. It could be blocked inside with something. I'll re-drill the holes and hit it with the compressor.
scarecrow
Titus-a-fishus
Post by Titus-a-fishus »
If it's not the rust
Perhaps you have accidentally closed the brass vents at the end near the valves?
Just a thought
TAF
Build it, don't buy it
scarecrow
Post by scarecrow »
Titus-a-fishus wrote:If it's not the rust
Just a thought
TAF
Never thought of that.
I know when I first got it, I adjusted the valves to just give a blue flame. Maybe with the buildup over time I need to adjust the valves out a bit more.
scarecrow
airhill
Post by airhill »
As Tater said I would check for spiders/webs, crap in the air inlet. Yellow is a sign of lack of o2, have had it happen to me twice (slow learner) :roll:
exon
Post by exon »
What is your banjo made of?
exon
and that's a fine looking rig, scarecrow!
Rollie wheels under the kettle and spirit table... stack of tires for the worm coolie...
Got an acrylic patio chair and a tv for the sports channel ? :)
exon
I am a pathological liar and functional illiterate.
Kentucky shinner
Post by Kentucky shinner »
make sure your air vents are open. your not getting enough o2
