"Is it possible the new one has an orifice for natural gas installed? Just a guess"
no as you would have a flame that you'd not believe.
a hi psi burner is made to work between 10 and 20psi
if you turn it below the 10 psi then they dont work right.
the vinturi is not big enough to draw in air at low settings.
Propane Burner Stink added Pics
Re: Propane Burner Stink added Pics
Well I converted my second pony keg into an electric boiler and don't have to worry about the propane issue any more. Stink is gone.
