Propane burner
LP NG gas burners of all types. Wood coal or Steam equipment
Propane burner
Postby 2goose » Tue Jan 14, 2014 7:58 pm
I have a high pressure propane burner similar to a turkey fryer. When made my first run of a sugar wash, after the initial heat up turning it down caused it to burn yellow and smokey. What it is the fix ?
2goose
Re: Propane burner
Postby NineInchNails » Tue Jan 14, 2014 8:23 pm
Turn the heat down and slow your warm-up. What size boiler ya running and what burner are you using?
NineInchNails
Re: Propane burner
Postby Prairiepiss » Wed Jan 15, 2014 12:32 am
Not enough oxygen for proper burn. Does it have a draft shutter on it? It should be around where the gas line connects. Usually you can turn them and open the air passage up. Allowing for more oxygen for proper combustion.
Or if it hadn't been used in a while. A spider may have made a nest in it. And its blocking the air flow. In which case just clean it out.
Prairiepiss
Master Distiller
Re: Propane burner
Postby 2goose » Wed Jan 15, 2014 10:02 am
Draft shutter is wide open. Runs bright and blue on high. It is brand new
8gal. pot.
2goose
Re: Propane burner
Postby 2goose » Thu Feb 27, 2014 1:44 pm
Still doing this. Think I will take it to the propane deal in town. Maybe the wrong jet ?
2goose
Re: Propane burner
Postby Prairiepiss » Thu Feb 27, 2014 1:54 pm
I still say its not getting the oxygen it needs. Have you tried to close the shutter some? Maybe the lower pressure can't pull enough with it open. So it doesn't mix well? Does it do it even without something on it?
Prairiepiss
Master Distiller
Re: Propane burner
Postby RBL » Fri Feb 28, 2014 11:27 am
+1. my father in law works on heaters and such. taught me shutter wide open on low isn't efficient.
RBL
Re: Propane burner
Postby 2goose » Fri Feb 28, 2014 3:09 pm
Ah Hah. Shutting the shutter a bit at low valve openings makes sense. Thanks. I'll try that
2goose
Re: Propane burner
Postby White_Lightning_Rod » Fri Feb 28, 2014 3:18 pm
Yea when I run mine on low had the same problem, dampered it down and cleaned right up to a pretty blue flame. And I no longer have to scrub soot off the bottom of the boiler now either.
HD forum, the best damn group of criminals and outlaws you'll ever meet.
White_Lightning_Rod
Re: Propane burner
Postby Kennylee » Tue Mar 04, 2014 9:09 am
Also try taking the burner apart and cleaning it with a wire brush, soot and rust build up on it too, and clean the gas tube with pipe cleaner, for some reason small spiders like to make this their home.
Kennylee
Re: Propane burner
Postby Appalachian spirits » Sat Mar 17, 2018 5:53 am
Spiders and insects LOVE burners. If the draft is open and its burning yellow you def have an air problem. Try cleaning out the burner and blow it out with compressed air.
Appalachian spirits
Re: Propane burner
Postby still_stirrin » Sat Mar 17, 2018 9:06 am
Zombie revival. But a great tip none-the-less. Thanks.
What is a Proof & Traille hydrometer: Alcohol-meter
Enzyme info: SebStar
HD Google search info: HD Google-how to
All about mashing grains: Braukaiser
Master Distiller
Return to Related Gas Accessories
Who is online
