Burner with Australian standards
Posted: Sat Jan 14, 2017 12:39 pm
by Copperhead road
I wanted either blichmann hellfire or bayou KAB4 but neither meet Australian standards, I have a ten gallon copper pot
Any suggestions from people in Aussie?????
Re: Burner with Australian standards
Posted: Sun Jan 15, 2017 2:42 pm
by cob
search 3/three ring burner
Posted: Sun Jan 15, 2017 8:35 pm
by Saltbush Bill
For a ten gallon boiler you don't need a fancy burner like those....just go to a camping store or similar and buy a standard old 3 ring burner.
You may want to invest a bit more in an adjustable regulator, but thats not really necessary.
Posted: Mon Jan 16, 2017 9:07 am
by The Baker
Of course you would know that gas rings that use propane bottles ( which probably most use) are different to the ones for domestic gas. Though you can adjust them by using a different (thing with the little hole in it).
Be safe.
Posted: Mon Jan 16, 2017 12:46 pm
by rad14701
The Baker wrote:Of course you would know that gas rings that use propane bottles ( which probably most use) are different to the ones for domestic gas. Though you can adjust them by using a different (thing with the little hole in it).
Be safe.
That thing with the little hole in it is a metering orifice... :idea:
Posted: Mon Jan 16, 2017 9:14 pm
by The Baker
Thanks, Rad.
I have only heard it called something else that I couldn't remember. Possibly a 'jet'.
Posted: Tue Jan 17, 2017 12:48 am
by cuginosgrizzo
yes, a gas jet, that needs to be changed depending of the gas type.
A gas jet
A gas jet
Posted: Tue Jan 17, 2017 6:17 am
by rad14701
The Baker wrote:Thanks, Rad.
Yep... The terms jet and metering orifice are interchangeable in many applications...
