Cooling and transferring option for 26 gallon grain-in mash?
Anything cooling/ condenser related to.Post here.
Postby Birzzz » Mon Sep 04, 2017 11:28 am
Hi,
we have a 26 gallon jacketed boiler that we plan mashing in. Almost everything is setup, but we are still wondering how we're going to cool to pitch temp and how we will transfer to fermenter.
We know know plate chiller won't work with grain-in mashes. What are you guys recommending equipment to cool to pitch temp a 26 gallon in-grain batch? If we're using a countertop wort chiller like this: http://www.homebrewtalk.com/showthread.php?t=577942
how can we pump that out? Also, is 1/2 diameter enough for grain-in (rey/corn) mash?
A normal brewer pump can't really handle solid if I'm not mistaken. Are there any alternative?
Thanks in advance.
Birzzz
Re: Cooling and transferring option for 26 gallon grain-in m
Postby shadylane » Mon Sep 04, 2017 12:04 pm
What is being used for heat transfer fluid in the jacketed boiler :?:
Can it be used to cool the mash
Postby Birzzz » Mon Sep 04, 2017 12:51 pm
Water. But I've heard using the jacket to cool was not really effcient. Isn't the case?
Also, we don't have an agitator..
Birzzz
Postby Birzzz » Mon Sep 04, 2017 1:44 pm
I think we will try to build a simple peristaltic pump as well a countertop wort chiller. Is this seems like a good idea?
Birzzz
Postby Birzzz » Mon Sep 04, 2017 1:46 pm
Birzzz
Postby shadylane » Mon Sep 04, 2017 3:06 pm
Birzzz wrote:Water. But I've heard using the jacket to cool was not really effcient. Isn't the case?
I mash, ferment and distill in a hybrid baine marie
The water jacket does a good job of cooling the mash
When I agitate the mash with a drill powered stirrer, it works even better. :lol:
Postby DeepSouth » Mon Sep 04, 2017 3:23 pm
You could build a spiral wound drop in wort chiller out of copper tubing. Just run cold water into one end of the coil and drop that thing inside the cooker.
DeepSouth
Postby Pikey » Mon Sep 04, 2017 4:46 pm
Is it essential to force cool the mash ?
Simple - TIMe - will get you there eventually :)
Pikey
Postby HDNB » Mon Sep 04, 2017 6:26 pm
Time works, but increases the risk of infection. Deep souths solution is easy cheap and effective. valved water through the jacket would be nice too for a permanent installation.
Shady's solution of doing it all in one is the easiest for sure.
don't waste your time trying to pump corn with anything less than 1 1/2" flexible impeller. and grind it fine...crack corn wears impellers fast.
now i drink for evil.
HDNB
Postby Birzzz » Mon Sep 04, 2017 6:34 pm
There are no impeller in a peristaltic pump. Would that make it a better candidate?
Birzzz
Postby HDNB » Mon Sep 04, 2017 7:10 pm
so...never seen a peristaltic pump that big, but corn will plug a 3/4" line no problem, the pump sucks the water out and the corn plugs the hole. done.
HDNB
Postby Birzzz » Mon Sep 04, 2017 7:28 pm
Thanks for the added info.
Geez, nothing is easy... Is there another viable option under 500$?
Birzzz
Postby zapata » Mon Sep 04, 2017 9:11 pm
I use a 50 foot 1/2" immersion chiller. Can you ferment in your mash pot, maybe if you add antifoam? Cuz thats the dream way to do it, no pumps, no drips, easy peasy.
zapata
Postby chickenfeed » Wed Sep 06, 2017 12:08 pm
I have always just waited for the temperature to drop naturally I seem to get a better starch conversion that way I've never had an infection problem and even if you did sometimes it turns out great I know with my rum and sour mash I deliberately infect it
chickenfeed
Postby shadylane » Wed Sep 06, 2017 1:39 pm
Birzzz wrote:Thanks for the added info.
Here's what I made to Mash, ferment and distill
viewtopic.php?f=83&t=59138
Postby greggn » Thu Sep 14, 2017 12:13 pm
... or from CSST. It's easier to wind and, depending on how quickly you want to drop temp, it's cheap enough you could build two or three and run them simultaneously.
________________
greggn
Return to Condensers/Cooling Methods
Who is online
