Cooling water
Anything cooling/ condenser related to.Post here.
Re: Cooling water
Postby Bushman » Fri Jan 12, 2018 6:52 am
RedwoodHillBilly wrote:
Yummyrum wrote:Bloody hell Redwood HB . How did you get away with screwing that sexy cooler to the Kitchen wall :D
I see my nuts kicked hard Iff'n I even thought about it :wink:
The "kitchen" is in the basement. It's my lab/man cave.
I showed that picture to my wife and she said he has to be single!
Re: Cooling water
Postby Bushman » Fri Jan 12, 2018 6:54 am
If any others have pictures or techniques to share, I find this to be a very useful thread!
Re: Cooling water
Postby BamaBill » Fri Jan 12, 2018 5:24 pm
kimbodious wrote:Hijack much! BamaBill's compact efficient design cools the water directly by making it fall down a column of chilled air and through a chilled permeable layer.
These guys have some nice setups.
Kimbodious, I had originally looked into some of these guys ideas. I had considered the radiator with a matching 12v electric fan and shroud straight out of a junkyard. I also priced the transmission coolers and looked at all sorts of fans.
It was my heating and air conditioning experience that led me to the cooling tower like I made. You can surely remove more heat directly than indirectly.
Mine isn't as sexy as some of those rigs, but it was a fast, easy build.
BamaBill
Re: Cooling water
Postby acfixer69 » Fri Jan 12, 2018 6:14 pm
What she was really saying Bush was if you do that you will be :D :D
AC
acfixer69
Re: Cooling water
Postby kimbodious » Fri Jan 12, 2018 8:33 pm
BamaBill wrote:It was my heating and air conditioning experience that led me to the cooling tower like I made. You can surely remove more heat directly than indirectly.
I worked in a sugar-mill, they had cooling towers on a massive scale! It is great to see how you have been able to draw from that design to make a scaled down really efficient device for cooling condenser water. I am collecting the components to make my own by copying your great design :thumbup:
kimbodious
Re: Cooling water
Postby cede » Fri Jan 12, 2018 9:01 pm
Few years back, I once tried to put a transmission cooler outside garage door in winter but water was coming back too cold !
It was around -15˚C outside.
Water should not freeze while being circulated, but it was really pushing to the limits :)
cede
Re: Cooling water
Postby kimbodious » Fri Jan 12, 2018 9:06 pm
cede wrote:Few years back, I once tried to put a transmission cooler outside garage door in winter but water was coming back too cold !
Were you getting huffing from the output?
kimbodious
Re: Cooling water
Postby cede » Fri Jan 12, 2018 9:28 pm
From the output of the cooler, just water close to 1˚C.
For the little story: down the road here, there's a guy who put a 1" hose from a spring coming to the surface. He really plugged the hose into the ground!
He runs that hose to the roadside for people to fill jugs. It's about a 100ft hose.
Water has always been flowing and I never saw it frozen down to -34˚C.
I've always been told here that when water flows it can't freeze.
cede
Re: Cooling water
Postby jonnys_spirit » Sat Jan 13, 2018 5:44 am
Hey Redwood, just Wondering what temp that water gets to on a run and over what period of time.
-j
jonnys_spirit
Re: Cooling water
Postby kimbodious » Thu Jan 18, 2018 4:28 am
Nearly completed building one of these BamaBill design coolers - BBC? It is a really quick and simple build. Really looking forward to running with this system! Huge thanks to BamaBill for his patience generosity with advice!
kimbodious
Re: Cooling water
Postby FlintHills » Thu Jan 18, 2018 9:19 am
kimbodious wrote:Nearly completed building one of these BamaBill design coolers - BBC? It is a really quick and simple build. Really looking forward to running with this system! Huge thanks to BamaBill for his patience generosity with advice!
I just finished my build last week, upscale to a 40 gallon version. Have to say it works pretty well once the filter material gets moist and have the fan running
FlintHills
Re: Cooling water
Postby Davel » Wed Jan 31, 2018 11:34 am
Great thread BamaBill.
I'm going to figure out something a long these lines for my setup & that'll save me the back and forth from the house to exchange jugs of ice.
Here in Canada air temperatures would be sufficiently low for about 11 month of the year 8)
Davel
Re: Cooling water
Postby BamaBill » Thu Feb 01, 2018 11:50 am
Davel wrote:Great thread BamaBill.
Thanks Davel.
That's what started this all for me, to not have to babysit that condenser water temperature. And, the useless waste of water.
BamaBill
Re: Cooling water
Postby MoonBreath » Fri Feb 23, 2018 12:11 pm
Can anyone tell me their constant water temperature ifn there is one..Ifn end of run temp much warmer than starting temp, it's not a fully efficient design or matched system.
Ifn the reservoir gradually heats up and doesn't maintain a steady constant temp, then no two runs will be the same.
Shots and heads get the preferred cold benefit, while hearts and tails get warmer and warmer water unless the work and water you're trying to avoid is used..Again no mention of stable, near exact temp through entire run..I would bet it'll never maintain 50-55° without bigger and mo money.
50° is preferred optimum temp for reflux condenser.
60° preferred spirit collection and proofing temp.
Gradually increased reservoir temp equals gradually less reflux, effecting proof and volume collected.
I use 3 gal water in seperate 5gal reservoir w/pump fed by return water through 25' ss pre-chiller packed with ice.
Reservoir stays 50°ish throughout the run with minimum work..For larger scale, 50' pre-chiller and larger reservoir would work fine imo..No fans, radiators, excess electric, and cost..
In the cooling condenser section.
MoonBreath
Re: Cooling water
Postby MoonBreath » Fri Feb 23, 2018 11:03 pm
Just run off 6+ gallon in right at 4hrs totally finished.
Used 2- 2ltr frozen pop bottles ..Removed ice, placing both ice chunks centered in pre-chiller, then pack good with ice.
Ended up using 5 and1/2 - 1gal bags of saved ice cubes.
Floating thermometer and temp gun said 3-4gal reservoir was 49° to 54° when topping off ice..Once the ice packs tight, easy peasy..I made initial mistake in ordering 3/8" pre-chiller.
Upgrading to 1/2" would be even more better imo.
I've never had anything ever close to 70°, let alone 100°+ on the return...Condenser exits and returns should be steady and luke to warm at most..Brewhaus pump been pumpin fer yrs.
MoonBreath
Re: Cooling water
Postby kimbodious » Fri Feb 23, 2018 11:34 pm
MoonBreath, sounds like you're happy with your set up for cooling condenser water. BamaBill is using a different approach and some of us are using variations of the same. Totally efficient? I wouldn't think so and doesn't have to be as long as it keeps condensing the vapour the whole run.
kimbodious
Re: Cooling water
Postby MoonBreath » Fri Feb 23, 2018 11:41 pm
Bushman wrote:If any others have pictures or techniques to share, I find this to be a very useful thread!
:thumbup:
kimbo, the subject line reads Cooling water.
And ya know claimed 113° reservoir temp isn't to far from Actual takeoff temps :wtf: ..Ole boys go broke letn worm get 113°.
Science can be a btch sometimes.
MoonBreath
Re: Cooling water
Postby kimbodious » Sat Feb 24, 2018 1:54 am
You got me there 113F that's like 45C? If I'm doing a stripping run down to 20% ABV the vapour temp is up around 208F. If BamaBill's reservoir temp isn't getting above 113F surely that's cool enough to knock down all the vapour on even a stripping run?
kimbodious
Re: Cooling water
Postby MoonBreath » Sat Feb 24, 2018 2:01 am
All your runs strips?...No.
What happens when you doin feints thru plates an it starts drippn at 140°?..Time hearts hit you done got hot, that is till you pack those 3-4 buckets back n forth..Workhorse.
Hot likker for you, not me. :D
I wouldn't spend to big gettn it right, cost vs viability.
MoonBreath
Re: Cooling water
Postby kimbodious » Sat Feb 24, 2018 2:32 am
8/10 of my runs are with a pot. The other runs are with a CCVM. If the condesnser water only gets up to 45C then all the vapour will be condensed and I will be a happy distiller.
kimbodious
Re: Cooling water
Postby MoonBreath » Sat Feb 24, 2018 7:58 am
Not enough there for me to advise 100s of folks to spend on it just yet..Sure you can build one to please the masses and all scenarios, but at what cost.
Better keep a cold towel in a bucket of ice water just in case.
May have to go old school for the Unpredictable.
#ragjocky :lolno:
Snazzy tho.
MoonBreath
Re: Cooling water
Postby piddler » Wed Mar 07, 2018 10:08 pm
thanks bama bill for posting your work on this setup. i’m still trying to figure it all out but know i don’t wanna waste all the water i did on my first 2 runs. i’m looking at building either a swamp cooler setup similiar to BB’s or an aircooled setup with a box fan like “shady lane” was good enough to document for everyone in another thread. i’m still a bit puzzled how you get the water back to the condenser if the pond pump is being used to circulate water over the cooling medium/filter material? the pic doesn’t appear as if gravity is being used?
it sure would be helpful if moonbreath and kimbodious could step up to the plate and post a pic of their setups rather than just teasing us novices with their claims,,, “i’m just sayin”?
piddler
Re: Cooling water
Postby pfshine » Wed Mar 07, 2018 11:03 pm
I ran a swamp cooler type setup for a little bit. I used an old water softener tank. A large PVC structure with four sides sticking up about 3' out of it with swamp cooler material on it. I used a sump pump with a wye to alleviate any increased pressure or deadhead problems to run the condensers and cooling supply. I used a decent sized heavy duty fan as suction for the swamp cooler. I piped the exhaust out of the area to keep the heat and especially the humidity away for maximum performance and a nicer work environment. The system worked absolutely fantastic, the water was always nice and cool. I couldn't ask for more. Then one particularly bad morning the sump pump died stopping all flow. I was running a boka that day, I heard a strange noise from the column and started to inspect. All of a sudden vapor and high proof distilate started shooting out or the vent in top of the boka. At this time I was still using propane, scared the piss outa me. At that point I decided to go to city water and go electric. I'm not trying to scare you just a reminder things happen. Put a flow meter on it with a buzzer or auto kill switch, anything, just to let you know you no longer have cooling.
pfshine
Re: Cooling water
Postby MoonBreath » Thu Mar 08, 2018 11:47 am
Mines posted here a few pages back..Under MoonBreath's Cooling Apparatus.
Sorry had trouble postn link.
No tease here, just time in.
MoonBreath
Re: Cooling water
Postby kimbodious » Thu Mar 08, 2018 5:12 pm
piddler wrote:thanks bama bill for posting your work on this setup. i’m still trying to figure it all out ...
Here is mine still under construction. The bottom tank has the sump pump in there. You'll have to imagine the pump output hose coming out from the black tank. The top part has an 30W exhaust fan which is drawing air in from the holes in the black tank and out through the top. You can see a dark band in the white drum; that is a ring of perforated garden hose for returning the hot water from the condenser. What you can't see is a dome of AC filter fabric between the white and black drums.
Warm water sprays and falls through a column of rising air drawn up by the exhaust fan . The air is chilled by being drawn through the moistened AC filter fabric. The water is cooled by falling through the chilled air and moistened AC filter fabric. There is a minor loss of water to evaporation and a heat input from having a sump pump in the smallish reservoir. I intended to address both by using a 44 gallon plastuc drum for the reservoir.
This is the AC filter fabric formed over a dome of wire mesh
kimbodious
Previous
Return to Condensers/Cooling Methods
Who is online
