the C.H.I.L.L.E.R
Re: the C.H.I.L.L.E.R
Nice work MF. It's a beauty. Have you thought about scratching the top bowls up to create more surface area? Maybe in the direction of flow? Won't be so shiny anymore but I'm thinking it would increase cooling. Or scrubbies on the outside of top bowls and small holes in catch bowls to rain on scrubbies?
Big fan of the design. Will soon start work on one 10' tall. Your work here has been inspirational.
Thanks, I'll keep you posted.
Good job mate, looks like you've got a great result! . Could you cover the bowl surfaces with a cloth of some sort to get maximum surface/cooling area?.
"Homer J Simpson"
"Homer J Simpson"
Come on guys, instead of making suggestions for improving Max's design, experiment with your own. I want to see your designs for coolers. Me... I want to play with rain gutters and waterfalls... and the gurgling sound they make.
There should ALWAYS be room for improvements! Otherwise this hobby gets stuck in a boring track...lampshade wrote:Come on guys, instead of making suggestions for improving Max's design, experiment with your own. I want to see your designs for coolers. Me... I want to play with rain gutters and waterfalls... and the gurgling sound they make.
I've got some plans of my own on a cooling system. Just need the time and some parts.
I wish I had a creek or a waterfall.
I think rather than play with the surface area, I'll improve air flow. the fan is rather anemic.It draws a mere 85 watts.I'd like to stick a bigger motor into that housing, because I like the housing. Unfortunately, it'll make it noisier. Right now it's far quieter than the trickling/soothing sounds.woodshed wrote:Nice work MF. It's a beauty. Have you thought about scratching the top bowls up to create more surface area? Maybe in the direction of flow? Won't be so shiny anymore but I'm thinking it would increase cooling. Or scrubbies on the outside of top bowls and small holes in catch bowls to rain on scrubbies?
10' tall, huh? That will be beautiful. Will you scale the bowl diameter up to keep the aesthetics? I gather you run a licensed establishment? I took a brief google look, but couldn't find anything.
I'd love to see photo's. If you have any questions....
Maxx
http://bit.ly/Maxxs_Bok
shining since 2013
shining since 2013
and +1Digital_Plasma wrote: There should ALWAYS be room for improvements! Otherwise this hobby gets stuck in a boring track...
emphasis mine
shining since 2013
shining since 2013
Maxximus Flavius wrote:I think rather than play with the surface area, I'll improve air flow. the fan is rather anemic.It draws a mere 85 watts.I'd like to stick a bigger motor into that housing, because I like the housing. Unfortunately, it'll make it noisier. Right now it's far quieter than the trickling/soothing sounds.woodshed wrote:Nice work MF. It's a beauty. Have you thought about scratching the top bowls up to create more surface area? Maybe in the direction of flow? Won't be so shiny anymore but I'm thinking it would increase cooling. Or scrubbies on the outside of top bowls and small holes in catch bowls to rain on scrubbies?
Maxx
Yes I am opening a distillery. Working on website right now. Bowl size will probably go up.
Finishing touches on the CHILLER. When I ran the 10 hour stint on Saturday, I bodged together a probe thermometer and a tuna can to catch the CHILLER discharge. And I had dropped an indoor/outdoor thermometer into the storage tank after coating it in melted paraffin. All very temporary. Two more Walliemart meat sensors and a SS pickle tray from... you guessed it, the dollar store.
I drilled an undersized hole in the plastic garbage can to stick the other probe in at the bottom and rebuilt my control panel.
I just gotta know what's going on
shining since 2013
shining since 2013
I had some leftover partially run wash that I wanted to extract the last little bit for my feints jar. So I fired up the contraption again and with cooler air temperatures, the CHILLER did it's job. Of course the differential will always be dependent on the ambient air temperature. Thankfully or maybe not I live in an Arctic country. Insert upper left is the discharge water from the condenser. The display beside it is the CHILLER discharge. I know there is so many ways to the path of happiness, mine happens to be doing this kind of stuff
shining since 2013
shining since 2013
Hi Maxximus Flavius I am considering building a tower as such, I was wondering how well an efficient it served since you started using this or any one else who basically uses this new setup.
Sorry, responding to a very old post. Haven't logged in for years.
I'm still using the chiller setup. Efficiency wise, It drops the temperature about 10-15 C. It's getting a little corroded though. Low quality SS.
Maxx
Maxx
shining since 2013
shining since 2013
Thats awesome its still kickin after 7 years bro
Very nice Dude, had a look at your boka build too, pretty much top of the line for back then (and even now)
I have a quick and easy idea to rough up your bowls - some hydrochloric acid will clean and then etch stainless pretty quickly, if you know anyone with a pool they will have plenty of it, otherwise its usually available in small qty's in most supermarkets (might be a little different in canada though eh?). it will need a bit of respect/saftey precautions when using and neutralising afterwards, but it would be a very easy way to kill 2 birds if the bowls are looking kinda crappy atm
I have foolishly used muriatic acid to clean rust stains off my asphalt driveway. Too much steel grinding with my angle grinder. The rust bubbled up into a foamy slime that rinsed off with water. I was using in undiluted. I didn't realize the the acid fumes were blowing back into my garage/workshop and anything that wasn't painted or well oiled must've got a good etching and rusted. I have a number of aircraft building tools that aged faster in one day than they had in 20 years.
Lesson learned.
Lesson learned.
shining since 2013
shining since 2013
